i thought we were comparing the wire-in ECU's? if so, both do low impedance injectors, so to the OP, no there is no difference in that regard. And i don't think e-throttle is going to be an issue for you, but i haven't checked if the xtreme can handle e-throttle.
  • Replies 100
The board in the G4 Plug-in storm is the same as the board in the xtreme, but the g4 storm wire in ecu is different,and only has 4x injector drives,so if your running a G4 storm wire in on a 6 cylender then you can only run the injectors in batch fire.
Yes, keep it to the V88 and the Extreme. All others are useless to me.
No i dont need electronic throttle, i've deleted it on my NEO. Track control pfft, Load dependant boost control solves that issue.
I'm driving Xspurt injectors which are 12 ohms anyway. No problem there.
Guilt_Toy.
You tune both of these ECU's a lot by the sounds of it. A few questions.
What i'm doing is setting up my car so that the ECU reads all sensors, Fuel pressure, Boost Pressure, Oil Pressure x 2 (1x at the oil pump and 1x at the engines main gallery, Fuel Temperature, Oil Temperature, Coolant Temperature, IAT etc.
Now what i'm wanting to do is set up the ECU to switch on or off outputs depending on the above conditions versus another condition.
IE. RPM vs Oil Pressure (oil pump sensor) . If oil pressure is 25 psi or above @ 2,000 RPM, condition is normal. (I'll have several points mapped accross the rev range - IE 4,000RPM - 50psi oil pressure and so on). IF the oil pressure drops below its set point at given RPM then an output on the ECU will fire, enabling a warning lamp and the accusump's electronic valve (preventing oil starvation). Also if RPM is below 300RPM, the output is always on (For engine pre-lubing via the accusump).
The second oil pressure sensor will be the same as above, apart from the fact i'd have it switch a different output or cut the engine, or rev limit. Something along those lines.
Another setup i'll be doing is Boost pressure vs Fuel Pressure. Ratio will be 1:1, for instance if i have a boost pressure of 20PSI, i should have a fuel pressure of 63.5PSI, if the fuel pressure drops too far at this level i would like to have the ECU go into rich and retard. Can these both do rich and retard?
I'll also be doing a few other tricky bits and pieces, but these two are the big ones i want to get under way.
Can they both do above?
Just to clear the air;
from the link website:
History:
Link was one of the very early market entrants twenty years ago. 2010 witnessed a turn-around in the market perception of the Link name thanks to the technical excellence of its product. The launch of the ViPEC brand has seen a new product pitched against high end competitors with outstanding results. Continued clear and unambiguous differentiation is further required to propel the ViPEC name higher
<p>
<br>
Just to clear the air;<br>
<br>
<span style="color: #282828"><span style="font-family: Georgia,">from the link website:</span></span><br>
<br>
<span style="font-family: Georgia,"><span style="font-family: Arial, Helvetica, sans-serif"><span style="font-size: 10px;">History:<br>
Link was one of the very early market entrants twenty years ago. 2010 witnessed a turn-around in the market perception of the Link name thanks to the technical excellence of its product. The launch of the ViPEC brand has seen a new product pitched against high end competitors with outstanding results. Continued clear and unambiguous differentiation is further required to propel the ViPEC name higher</span></span></span><br>
</p>
who is going to propel vipec to great heights now since ray has retired and dirtgarage is banned ?
Edited by Walk510
Still laugh about how hard dirt pushed vipec thrashed the rest then ended up with the gold box anyway. I guess the superior idle didn't matter on a drag car after all. Anyone know if his rebuilt the mercury 34gtr 26 recently? Lol
Edited by Ryan1200
Motec has been the ecu for many motorsport applications but the Link G4 Extreme is now being used by the new NZ Supertourer series:
http://www.linkecu.com/newsfromlink/v8-supertourers-are-go
The M84 is a versatile, race-bred ECU that is suitable for a broad range of high performance applications, including engines with up to 8 cylinders. It also suits rotary engines with twin, triple or quad rotors.
This new, entry level ECU is based on the advanced technology in MoTeC's benchmark M800, with a package of features to suit more moderate system requirements. It includes on-board Wideband Lambda plus 512 kB of data logging memory as standard.
Now with Nitrous Injection and 100 Hz max logging rate.
Install it as a stand-alone ECU or as part of a complete motorsport-ready engine management and data acquisition solution.
and about $2500
<p></p>
I'm sure Paul would love to continue his crusade if the mods would reinstate his account...hell, that la bumba idiot's been hit with the ban stick about half a dosen times and his still on here.
But i dont know the history and that decision is for the mods....now back on topic..
Guilt_Toy.
Interesting ideas. If this can be set-up, i'm sure guilt toy knows how to do it, but have you spoken to your tuner directly as to whether they are confident to do it?
Also, have you considered the haltech - from memory it has accepts all of those inputs, although its a little pricey aswell.
Edited by wedge_r34gtr
Huh, Paul from Red R Racing (swiper the fox) has been banned on here? What the??
Haltech, meh, my tuner says they are limited with what they can do, limited inputs and outputs.
He said for what i want to do, they are too limited and not configurable enough.
A few of the track RB30s have the Link watching for lack of oil pressure. I bought a high quality 0-150 psi pressure sensor from Rips (they are widely available) and my G4 will be loaded with minimum oil pressures for each gear and cut the engine if they are not maintained. There was a video on U tube of a GTST with an RB30 and you could hear it stuttering at a couple of points at Hampton Downs as the oil surges away from the pickup. No doubt it can be made to switch an accusump. My plug in G4 has spare inputs - The wire in Extreme will have more as well as more computing power.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
