Yeh he complains but he kept the stock throttle body for one , with his upgrades there is no way he shoulf still be running that..... and yhere is also someone in that forum sayin he got quicker spool, better response, a minor hp gain and no bleed off at higher revs ....... And there is no dyno sheets anyways , thats not results btw
Plazmaman told me that the std throttle body is fine for my power (TD06-20G). They said a throttle body would help improve performance further but they understood why I had reservations about spending more dollars given the results I was getting.
Plazmaman were great to chat to...they returned calls promptly and were helpful with things I need to check but I am about 90% sure they arent issues as I had already checked them all as part of the original install. BUT, I will be trying it once I get my other car back on the road.
Give it a nudge, will be interesting to see what results you get. I am making over 300rwkws now out of my RB20 so if there is something that will help make it it a little easier with less then 23psi etc then I am willing to give it a try. I still have Poncams laying around which are getting trialled after my next track day
...oh and for what its worth part of the reason I keep my engine pretty basic is that I happen to know a guy with a Gibson R31 GTS-R and its real interesting to hear all the things they tried and ended up with to end up with the 420hp odd that they raced with and likewise my tuner is a fan of a lot of std gear on the engine for a responsive street/track engine combination
  • Replies 112
Wow this type of stuff pisses me off, I know the guys at Plazmaman well I go there all the time and they deserve every cent of what they charge. The amount of r&d that goes into their gear is ridiculous and they will not be satisfied until they are sure it is the absolute best and cannot be beaten. For someone to come along and steal their design and brand it as there own is immoral and wrong, I have seen first hand the number of intercoolers they have in the scrap bin because they weren't happy. They looked fine to me but they simply didn't meet their strict quality control. Buy off the guy who put the effort in to getting it right!
One thing people are forgetting or not considering is that whilst the Freddy manifolds are cast these Plazmaman knock offs are welded and it pays to be prepared to take the thing off at one point and weld up splits. You hear of cheap welded alloy manifolds splitting and it's my guess that it is going to be worse these days with E85 and people throwing more boost at their cars
The 1JZ engines we have here run 60 psi boost and 150-200 shot of gas and don't have problems with the custom plenums that are on them. At the end of the day it all comes down to whether the person making the thing knows what they are doing. Any wanker can weld a box up and call it a plenum. Making it work and making it quality are two totally different ball games
please oh please sent me the details of said 1j's!!!!!
1. VR Commodore Ute - 1JZ (fastest and quickest 1JZ in Australia - currently doing 9.1 @ 153) Owners name is Derek
2. LJ Torana - 1JZ (quickest/fastest manual 1JZ in Australia - 10.3 was his time with the manual I believe but he put an auto in and now does 9.6 @ *edit* was 147mph) Owners name is Danny
Photos of the commodore are on my Facebook but the Torana is on Youtube on EFI's page
http://www.facebook....14465228?ref=hl
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
