Sweet result and love the vid
That's what I want power wise from the racecar when I build it
Congrats on the house as well Ruxis and welcome to never ending bills bills and more bills LOL
Random house news for me is I just ordered a new kitchen which Melisa is happy about
Am thinking with all the offers floating around I should mention I have a Karcher of anyone needs to clean the car engine bay etc
Awesome to see the the group working together :yes: we have a good thing going....
Car has had its final tunes today, has been set on -
311rwkw on pump 98 low boost
340rwkw on E flex low boost
357rwkw on E flex high boost
These were all tuned for safety and reliability and show the turbo is out of puff...
Some car news from me
Had an early finish so got a head start on detailing the car.
I forgot how much work it can be, have spent all arfternoon on it and not even half finished
I've only got the bonnet roof rear spoiler and boot lid done so far
The rest can wait till tomorrow to get the final polishes and waxes then the windows wheels and interior
Good work mate, look forward to seeing your car again next weekend..
Going down to get the car Monday mate so will definately be there :D
Is there much midrange or torque difference between low and high boost?
And where do you get e70 around here?
3 servos so far in the Newcastle area... Charlestown (that reminds me, better fill up on that meet up), Hamilton and i think Swansea.... Its good stuff!
There isnt going to be a huge difference between the 2 i dont think mate, still more than i can handle lol
And now I'm finished
Taken long enough but is so much better
Today was one pass with power finish
Two goes with the final finish
One with the sealing wax and finally some P21S carnauba wax by hand
Put the rear spoiler back on cleaned the wheels, windows and interior and is now all shinny again
PM me a moby number or email and can send them
Wouldn't know how to post then to be honest
i did the other day about the diffuser lol. I'll upload them for you if you want.
You can use photobucket.com to upload images --> create an account (free) and then just follow the prompts. it gives you a url that can be pasted into your posts.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
