Sounds good mate! Hope the house is going well... We have been interstate a bit and off thrashing the car as often as we can :D
Ooh let me know how the new track goes :yes:
We are off to Wakefield again!
New track goes well, didn't realise the journo was there. I made the local paper
http://www.portstephensexaminer.com.au/story/2373368/gallery-no-hiccups-for-ringwood-hill-climb-event/
  • 3 weeks later...
Hey guys.. im having a dyno day on sunday at Heatherbrae.
https://www.facebook.com/events/526415517464770/
adress is 62 heather street heatherbrae, starts at 9am.
60$ for 3 runs and a BBQ with drinks.
10$ if you want to spectate and BBQ.
cheers
  • Like 1
  • 2 months later...
Hi Guys
Trying to find some E85 in Newcastle or some where closer to Forster.
Cheers
You can get United at Metford... There are 2 servos around that area with it! Probably your closest option...
  • Like 1
  • 1 month later...
Hey guys. I've inboxed a fe of you regarding an upcoming cruise/lunch.
For those who i havent and may be interested, it would be good to get a few local HUnter Valley/Newcastle/Central coast numbers together. Here is the link to the cruise:
  • Like 1
  • 3 months later...
Soooo anyone still alive in here? Just got my car running again would be good to have a meet up or something :)
Loooooooooooooooool! I havent seen this thread in a long while! :P
I think half of us are off getting married etc man haha
  • Like 1
5 months single after a 4 year relationship, band died off, skyline is main focus now haha. I'm keen for a cruise/meet.
This should have been the case from the start :P
  • Like 1
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
