Check all the usual things Quality of radiator fluid, are you losing any? Thermostat fully opening? system retaining right pressure? waterpump not too wornout? condition of radiator interior ,hoses and water passeges? oil cooler? theres a start
https://www.sau.com.au/forums/topic/40243-overheating/#findComment-825714
Yep, GTRs run hot when giving them a bit of a hammering. I have been warned by many people now not to even think about taking the GTR to Q.R. until I have a nice oil cooler, a decent sump baffle setup, bigger oil pump, and bigger radiator. This has been told to me by Ernie (Skyline imports), Gavin Woods, Bruce (LEDA suspension) to name a few, and Sydneykid has also mentioned this. So unitil these things are completed on me car, my Sprint Events at Q.R. are over, not taking the risk.
I can get the oil temp in mine to the "near danger zone" with a quick drive through the mountains, hate to think what it could get to on the track.
https://www.sau.com.au/forums/topic/40243-overheating/#findComment-826263
rb26dett, you think the TRUST cooler may not be up to the task ? What experience have you had and what do you recommend ?
Squizz, I have the same problem up around Nebo, temp climbs real quick. We should organise a drive.
the oil cooler is in my car. it holds temps to just above the 70 mark on the gauge while cruising...
but when i really get into the driving, temps still creep up, albeit slower...this is all experienced on mountain runs. if u don't pay too much attention to the oil temp gauge u'll find it sitting at half in no time at all...
plus i'm running about 10 litres of engine oil with a trust sump...still the temps go up....
and the runs are done at night...hate day runs too much traffic, plus it's cooler at night...also done with heater venting into cabin...n still...problems with oil temp
https://www.sau.com.au/forums/topic/40243-overheating/#findComment-835776
What's the ambient temp in the engine bay like when the oil starts to run hot. if you can get the engine environment temp down it may help. Didn't 'Godzilla' have coolers on just about everything
Just driving normally it's bloody hot under the bonnet. Some venting may be in order...
https://www.sau.com.au/forums/topic/40243-overheating/#findComment-835818
aust spec 32 gtr has oil cooler for transfer case, that about the major difference to jdm 32 gtr. So engine/transmission/diff oil coolers are still needed (in order of preference).
I'm not sure how much the sump got heats up by the front diff and vice versa, as you can now get aftermarket front diff cover for extra oil capacity with more cooling fins.
https://www.sau.com.au/forums/topic/40243-overheating/#findComment-835910
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
