  • Replies 124
Posted Images
20 confirmed
Me + 1
Stivvs 6 + 1
Luke GTR + 1
Bob + 1
Vorse + 1
Extatic + 1
runnin4life
Greg R31
Humbla
Jane
Deka
Aggroman
Crashdown
FeZ25
These numbers are now confirmed for lunch. There is a BP that sells Ultimate 1 min from Kravings. Its booked for 12:30 and will be under Skylines Australia.
Realy looking forward to this,staying at bass hill sat night.
Where are you sydney peeps meeting up? :action-smiley-069:
What about at the Ettamogah Pub in Rouse Hill? - http://www.ettamogahhotel.com.au/
It's sort of on the way but just an idea?
Its about 30 kms to Kurmond ........ Say 40 minutes easy.
Get there at 11;00am for a chinwag and catch up? Lunch is booked for 12:30pm so we could leave at 11:45am.
Thoughts?
Bob.
20 confirmed
Me + 1
Stivvs 6 + 1
Luke GTR + 1
Bob + 1
Vorse + 1
Extatic + 1
runnin4life
Greg R31
Humbla
Jane
Deka
Aggroman
Crashdown
FeZ25
I had a +1!
My bad i only read ur first pm which was just for u. Should have read ur second lol.. Bring ur +1. Ill sort it out.
Looks like neither my +1 or myself will be making this trip unfortunately.
After 9 weeks of being assured my car will be finished at the panel beaters this week, they've delayed me again.
Hope you guys have a good run!
your plus 1 can have my spot, my fuel pump just dyed, I've ordered a new one, but wont see it until monday, so I can't make it
where you located?
I've got a 2nd hand gtr pump you can use.
bring another car.
the missus and myself are going to be rocking her Mazda 3....
where you located?
Guildford west.
I've got it running after cleaning the pump out so I'm back in!
Luke are you meeting everyone at the ettomogah or heading straight to there, I ask because would you be able to bring the pump as a 'just in case" for me?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
