  • Replies 124
Posted Images
20 confirmed
Me + 1
Stivvs 6 + 1
Luke GTR + 1
Bob + 1
Vorse + 1
Extatic + 1
runnin4life
Greg R31
Humbla
Jane
Deka
Aggroman
Crashdown
FeZ25
These numbers are now confirmed for lunch. There is a BP that sells Ultimate 1 min from Kravings. Its booked for 12:30 and will be under Skylines Australia.
Realy looking forward to this,staying at bass hill sat night.
Where are you sydney peeps meeting up? :action-smiley-069:
What about at the Ettamogah Pub in Rouse Hill? - http://www.ettamogahhotel.com.au/
It's sort of on the way but just an idea?
Its about 30 kms to Kurmond ........ Say 40 minutes easy.
Get there at 11;00am for a chinwag and catch up? Lunch is booked for 12:30pm so we could leave at 11:45am.
Thoughts?
Bob.
20 confirmed
Me + 1
Stivvs 6 + 1
Luke GTR + 1
Bob + 1
Vorse + 1
Extatic + 1
runnin4life
Greg R31
Humbla
Jane
Deka
Aggroman
Crashdown
FeZ25
I had a +1!
My bad i only read ur first pm which was just for u. Should have read ur second lol.. Bring ur +1. Ill sort it out.
Looks like neither my +1 or myself will be making this trip unfortunately.
After 9 weeks of being assured my car will be finished at the panel beaters this week, they've delayed me again.
Hope you guys have a good run!
your plus 1 can have my spot, my fuel pump just dyed, I've ordered a new one, but wont see it until monday, so I can't make it
where you located?
I've got a 2nd hand gtr pump you can use.
bring another car.
the missus and myself are going to be rocking her Mazda 3....
where you located?
Guildford west.
I've got it running after cleaning the pump out so I'm back in!
Luke are you meeting everyone at the ettomogah or heading straight to there, I ask because would you be able to bring the pump as a 'just in case" for me?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
