WTF... that's my GIF... get FARKED I'MMA EMAIL THOSE FLEA RIDDEN MUTTS.
That's MY GIF made from MY AVI, which I have and can provide as proof...
as for that pic, I've only ever posted it on here for jack to use as an avatar... so I know you're a member on here... so make sure you take heed to this post.
https://www.sau.com.au/forums/topic/40266-burn-baby-burn/#findComment-825995
I'd be surprised if any of those MPEGs are from actual cars they've kitted... stealing scumbags... and jack's blowin fire cos his manifold was red hot lol not coz he had some pansy ass arsonist agent orange shit.
https://www.sau.com.au/forums/topic/40266-burn-baby-burn/#findComment-825999
here's a copy of an email I just posted to them...
I am the author of this animation, and have more than enough conclusive proof to prove this. To make it any simpler for you folk, let me point out some facts:
1) This event took place on the BMT Dyno in Fairfield on an SAU Dyno Day
2) the Car is owned by Jack, a member of SAU Victoria
3) He DOES NOT HAVE A FLAMETHROWER kit fitted to his car
4) The reason his exhaust is shooting flames is because his manifold is glowing hot and has a "slighly modified" Catalytic Converter.
I find it personally insulting that you would degrade a car that I am very fond of by slagging it with your product. Please don't belittle this car with your peddling. I really cannot say how many of the images on your website are of actual cars you have worked on but I can gurantee you that you have never worked on that Silver GTR.
Further, I am a Graphic Designer, who has often had to deal with digital data theft and copyright breaches (mostly because I had to sit through a whole year of lectures on the subject), so you will no doubt realise that under Australian copyright laws you are in full breach of my personal property (this item will continue to be my property for 50 years after my death if I have not indicated a transfer of rights over to someone else).
Now I have done my duty of giving you a warning/heads up.
I give you 72 hours from the time I send this for you to remove the images from your website.
Regards,
Shan Moorthy
PS: next time you hire a webdesigner to design your company website, make sure he's accredited, and that he knows how to remove a digital signature from a GIF file before plagarising it.
https://www.sau.com.au/forums/topic/40266-burn-baby-burn/#findComment-826007
as for their "Flame thrower kit" god who doesnt know about screwing a spark plug into your exhaust pipe... i mean oooerrr wizzo! a spark plug to screw into my exhaust... glad they made a kit, i'm to unco to do that myself. (please note sarcasm at the end there
https://www.sau.com.au/forums/topic/40266-burn-baby-burn/#findComment-827177
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
