Help needed urgently...........
Guys i believe that my car has gone into limp mode , ie not revving past 2000rpm.
Now I went to Scott's place and we did the solder trick on the socket of the AFM (Z32) and swapped it with another one he had at the time and still didnt fix it . we suspected maybe that AFM may of been faulty. Strangely this wouldnt happen cold and would only occur when the car was warmed up and ONLY when restarted ie drive for xkm and then stop and then restart the problem would occur (but not always).
Anyway its been fine for a week or too and in the meantime i bought another z32 AFM as a spare just in case. I decided to change it and it happened last night on the way home (car not warmed up)
Now it happend first time this morning again fine for about 1 minute getting out of garage and up the street and the friggin thing is doing it again....
Does anyone have any idea what I can do as this is driving me NUTS!!!!!!!!!!!!!!!!!!!
Regards,
Draren
Edited by itshimdazza
https://www.sau.com.au/forums/topic/402672-limp-mode-help/
It gets to 2000rpm then cuts and drops done to somthing like 1000 imagine brp brp brp if i hold it WOT, ie it would kill then climb back up the kill etc
Oh also it dosnt matter if your in gear or just revving it in neutral
darren
https://www.sau.com.au/forums/topic/402672-limp-mode-help/#findComment-6402045
visited Scotty again and resoldered in a new AFM plug as the old one had residue (oxidation) on contacts but didnt fix it.
Unpluged the TPS and hello......it can rev past 2000. Looks like the TPS maybe shot. This may be a give away due to the car idleing high most of the time around 1700-2000...
off home and swap it over with my spare and will let you know how it goes... I was always suss with it anyway as the vollage was always high in it 2.5v or there abouts on idle...
Dazza
pm'd artz & sunkist who were over at Scotties....
https://www.sau.com.au/forums/topic/402672-limp-mode-help/#findComment-6402259
yeah ,
sorry for the late reply (went out) looks like the TPS can infact cause the car to go into limp mode. My ecutalk confirmed the voltage at idle some 0.5volts whereas before was somthing in the 2.5volts. so thanks heaps guys .Looks like we will have to all remember this in future ....
Check AFM ...
Check TPS
if you are limping....
regards,
Darren
https://www.sau.com.au/forums/topic/402672-limp-mode-help/#findComment-6402880
yeah , sorry for the late reply (went out) looks like the TPS can infact cause the car to go into limp mode. My ecutalk confirmed the voltage at idle some 0.5volts whereas before was somthing in the 2.5volts. so thanks heaps guys .Looks like we will have to all remember this in future .... Check AFM ... Check TPS if you are limping.... regards, Darren
atleast you found it.. how was driving home with it unplugged? lol no issues?
Haha, looks like we both learnt important lessons in fault diagnosis today.. Just start unplugging shit...:D
"today kids, we are going to learn how to fix things by potentially making them worse"
https://www.sau.com.au/forums/topic/402672-limp-mode-help/#findComment-6403005
R31Nismoid,
Nay dont have powerfc .
I have a Nistune so no display. It only comes up on my ecutalk which shows several voltages temps etc.
There was no error codes except for this "Fuel Temp Sensor" which I really dont have any knowledge what it is or even what it does
Dazza
https://www.sau.com.au/forums/topic/402672-limp-mode-help/#findComment-6403253
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
