Have searched and not found much,
so im interested in going either E85 or water/meth to get my gtx3076 onto some higher boost,
It seems the cost of both is about equal, so what is best? do they both have pretty much the same result?
Im leaning toward the water/meth injection because of the ease and cost of filling up a small bottle with water and methanol but can this still be effective in bringing on boost earlier ( 500rpm)?
My goal would be to keep the tune very safe on stock motor but to improve the area under the graph with as little hassles as possible, also to fry some tyres in second gear on 4000rpm :domokun:
https://www.sau.com.au/forums/topic/402697-e85-vs-watermeth-injection/
  • Replies 46
Posted Images
water meth doesnt bring the turbo on earlier as its not injecting anything until you are on boost or starting to get on boost, it allows more ignition timing and cools the intake fuel/air mixture meaning you can lean on the tune more.
there is a big thread on it in this section.
i was reading it can be set up to the airflow meter , so it could come on even before boost, but even on 2000rpm its starting to boost so by 3000rpm or 3500rpm, would the boost be comming on harder and faster?
its not so much how much boost by when, its also how fast it builds as well , so in that way could it get upto full boost faster ?
It doesn't make more air go into the turbo so no doesn't bring it on earlier.
Does let you play with timing which can result in some midrange and top end changes
Wouldn't expect it to spool faster though.
Water meth is explained a lot and so is e85
They are both pretty much on par.
So it's just up to what you feel like doing.
One thing I guess you could say is if the meth fails for any reason you can do some damage.
But e85 is safer in that regard.
If you have access to e85 around you then I would probably be going that route.
Some systems run of IDC, maf voltage, boost but I dont think its going to give you any improvement in off boost performance.
If you set it up to start injecting at like 5-6psi then you might get a little bit more down low, but your turbo will probably build the boost quick enough to not really notice it too much I dont think.
my tuner said theres still a bit too much varience in pump fuel unless i buy E85 in the 200L drums which is guarenteed 85%, but only thing with this is the constant cost of it,
would i just have it tuned very conservatively incase it gets filled with say 70% at pump so theres no danger? the water/meth seems alot more simpler, just fill a small bottle up ... i know there is some fuel stations not far away with the E85 at the pump..
hmm, tell me what i should do to make this gtx3076 fry the tyres with ease, currently gets a bit loose at the back on 5000rpm, thats too long to wait, i want nasty wheel spin on 4000rpm...
is this the point where i start building an RB30 bottem end?
Edited by SliverS2
Yeah I was gunna say learn to clutch kick, then I read your spec list Mark and the problem is pretty obvious...your clutch is no good..your setup should be good for 350kws dude..how can you expect to get close to that with a 250kw clutch..?
Go find a better tuner.
Everyone else seems to be able to tune accordingly without any issues what so ever.
If your tuner has that opinion of pump e85 then I wouldn't be getting him to do either tune. The safety offered by ethanol is required imo to tune at 300+kw power with a GT30 rear. Yes it has been done but those setups are knock limited, there is no point pushing petrol to that point as the 98 fuel variation will kill it quicker.
Get e85 tuned a little rich and you will be fine on any ethanol fuel, if you are worried just slap a wideband in the dash and add 98 as required.
I haven't done water injection on any of my cars yet although I plan to direct inject water into a spare high compression VQ25 I have here. If you could inject it on the exhaust stroke you would have the steam to help spool the turbo, possibly gaining some response back. Perhaps it could work in the manifold too?
That sounds like an interesting prospect, anyone know much about that?
Your doing it wrong haha
My SS1PU hardly holds in 3rd these days
Also why do you wanna fry tires
I can't wait to setup my rears to hold 1st and 2nd boost.
cause frying them feels good, lol
but i get your point, 3rd pulls hard and is just about ready to get loose back there so im not complaining about that, the issue is its just 500rpm to 1000rpm too late to be exciting on the road, on a track it would be quite happy and probably perfect for a drift car where it spends alot of time on the top.
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
