Have searched and not found much,
so im interested in going either E85 or water/meth to get my gtx3076 onto some higher boost,
It seems the cost of both is about equal, so what is best? do they both have pretty much the same result?
Im leaning toward the water/meth injection because of the ease and cost of filling up a small bottle with water and methanol but can this still be effective in bringing on boost earlier ( 500rpm)?
My goal would be to keep the tune very safe on stock motor but to improve the area under the graph with as little hassles as possible, also to fry some tyres in second gear on 4000rpm :domokun:
https://www.sau.com.au/forums/topic/402697-e85-vs-watermeth-injection/
  • Replies 46
Posted Images
water meth doesnt bring the turbo on earlier as its not injecting anything until you are on boost or starting to get on boost, it allows more ignition timing and cools the intake fuel/air mixture meaning you can lean on the tune more.
there is a big thread on it in this section.
i was reading it can be set up to the airflow meter , so it could come on even before boost, but even on 2000rpm its starting to boost so by 3000rpm or 3500rpm, would the boost be comming on harder and faster?
its not so much how much boost by when, its also how fast it builds as well , so in that way could it get upto full boost faster ?
It doesn't make more air go into the turbo so no doesn't bring it on earlier.
Does let you play with timing which can result in some midrange and top end changes
Wouldn't expect it to spool faster though.
Water meth is explained a lot and so is e85
They are both pretty much on par.
So it's just up to what you feel like doing.
One thing I guess you could say is if the meth fails for any reason you can do some damage.
But e85 is safer in that regard.
If you have access to e85 around you then I would probably be going that route.
Some systems run of IDC, maf voltage, boost but I dont think its going to give you any improvement in off boost performance.
If you set it up to start injecting at like 5-6psi then you might get a little bit more down low, but your turbo will probably build the boost quick enough to not really notice it too much I dont think.
my tuner said theres still a bit too much varience in pump fuel unless i buy E85 in the 200L drums which is guarenteed 85%, but only thing with this is the constant cost of it,
would i just have it tuned very conservatively incase it gets filled with say 70% at pump so theres no danger? the water/meth seems alot more simpler, just fill a small bottle up ... i know there is some fuel stations not far away with the E85 at the pump..
hmm, tell me what i should do to make this gtx3076 fry the tyres with ease, currently gets a bit loose at the back on 5000rpm, thats too long to wait, i want nasty wheel spin on 4000rpm...
is this the point where i start building an RB30 bottem end?
Edited by SliverS2
Yeah I was gunna say learn to clutch kick, then I read your spec list Mark and the problem is pretty obvious...your clutch is no good..your setup should be good for 350kws dude..how can you expect to get close to that with a 250kw clutch..?
Go find a better tuner.
Everyone else seems to be able to tune accordingly without any issues what so ever.
If your tuner has that opinion of pump e85 then I wouldn't be getting him to do either tune. The safety offered by ethanol is required imo to tune at 300+kw power with a GT30 rear. Yes it has been done but those setups are knock limited, there is no point pushing petrol to that point as the 98 fuel variation will kill it quicker.
Get e85 tuned a little rich and you will be fine on any ethanol fuel, if you are worried just slap a wideband in the dash and add 98 as required.
I haven't done water injection on any of my cars yet although I plan to direct inject water into a spare high compression VQ25 I have here. If you could inject it on the exhaust stroke you would have the steam to help spool the turbo, possibly gaining some response back. Perhaps it could work in the manifold too?
That sounds like an interesting prospect, anyone know much about that?
Your doing it wrong haha
My SS1PU hardly holds in 3rd these days
Also why do you wanna fry tires
I can't wait to setup my rears to hold 1st and 2nd boost.
cause frying them feels good, lol
but i get your point, 3rd pulls hard and is just about ready to get loose back there so im not complaining about that, the issue is its just 500rpm to 1000rpm too late to be exciting on the road, on a track it would be quite happy and probably perfect for a drift car where it spends alot of time on the top.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
