  • 4 weeks later...
Carbon bonnets in most cases can be cut and polished just like paint( except dry carbon)
megulars m105
Or farcula and a buffer
Then use some fireglaze in top of a show car glaze applied with buffer ( do not use lambswool pads!!!)
other choice sand up from 4000 to 12,000 grit then above , if the bonnet has cleared paint then sand carefully and repaint with diamond clear from DNA paint
It can be flow coated with a new product that looks like 25 mm of standing water its so shiny but the cost and process is a big one left for a carbon layer , the product has to be imported from USA not sold here but is UV stable and used on jet engines cowl so heat from the sun wont touch it , note real carbon sands real easy and you can buff right thru it in a flash so use care
Most bonnets sold here arent UV stable and get crappy in a few years if left untreated or in sun a lot
Paint it body color for the "its stock look"
Mine is a FRP though , and it has big arse Aerocatch locks on it so its not as stealthy as it once was, but at least now it wont fly up at speed.
Ever since i got a bad recommendation from autobarn and it ruined my cf bonnet, ive used the meguiars plastx cleaner and polish.
It still need to be redone every now and then but the car rarely leaves the shed when its raining so it stays good for a while.
Ive actually just looked at the bottle and its the lowest restoration fix of there products. there is a moderate and severe to try. So until i paint it to match car was going to try the moderate if i can find it.
But it works just like polish and ive never had a problem with it. And when i did use the stuff i was recommended from autobarn the bonnet just about matched the white paintwork so it does its job.
If its sprayed clear , treat it just like a car paint , wax it etc, just remember the clear will be much thinner ( some will be epoxy clear other lacquer which cracks and hazes fast)
You can also get what is called "blushing " kinda a wipe off hazy look thats from non UV stable and possibly chemical reaction still occuring in the epoxy from the heating, in that case let it cook in the sun one hot day then wash with good car soap not kit or some crap like dish soap
And show car glaze and your fav good paste wax
Once again not turtlewax, kit or cheap crap
Using only microfiber towels to wash and dry snd polish not lambs wool for anything or sponges
If you drop the rag grab another one dont use it again
And when you wash rags DO not use fabric softener it leaves a haze on your car and smears
The epoxy used on carbon bonnets is paperthin in most cases so sanding or even a detailer polisher can be dangerous and require a reflow of epoxy or even carbon repair which is paper thin too
Edited by Carbon 34
  • 5 weeks later...
depending on how bad it is take it to a mob called aquadip i have seen them fix up faded carbon bonnets just by cutting back the resin and reclearing it again i think it would be better because clear takes alot longer to fade and go that yellow colour than resin
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
