I've had my 33 for about 18 months now and have read everybodys posts (with envy) when they have bought their mods etc.. Now its my turn.
I had a Nismo cluster and centre gauges put in last week. I ordered a Power FC through Japanese Import Parts which should be hear soon and ordered a set of Volk TE37's from Dave which will take a bit longer but well worth the wait.
I may even get some cam gears installed depending on finances.
Waiting is a pain in the arse.
Alan
https://www.sau.com.au/forums/topic/40303-it-has-begun/
Yes, I like to think that James.
What it means is the distance from the inside of the wheel where it touches the hub to the inside of the rim at it's furthest point (I'm pretty sure). You'll notice the difference between mine and Andrews. His look a lot more deep where as mine dont as the offset is a higher value. It's so they dont hit the calipers and fit under the wheel arch correctly. If you used the same ofset on a GTT as a GTR they'd hang out the arch's.
https://www.sau.com.au/forums/topic/40303-it-has-begun/#findComment-827327
Alan,
Where did you pick up the nismo dash from? not that it matters now but I can get pretty good price on them new now..
Also, can I suggest if your going to get cam gears, do it before you tune the pfc.. otherwise you'll keep spending money on tunes everytime you put something on which can become costly.
https://www.sau.com.au/forums/topic/40303-it-has-begun/#findComment-827416
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
