Came across a fella on another forum today who reckoned he was making 300kw/400hp on 16 pounds with these :D Gave me the lol's
dont laugh, my mate is making 286kw @ 14.5psi with gt-ss
Edited by SiR_RB
Hmmm interesting. But then and again I was making about 350hp with the ceramics at about 1 bar. I guess that with awesome turbos and an equally awesome tuner these crazy figures are possible.
Also, according to that chart flowing around the twin -9's are rated at about 560ps...but I'm pretty sure that's taken at the engine??? So if you were to account for drive train loses....you'd be getting back down to somewhere around the 480-500 mark. (don't know the conversion factor for ps to hp of the top of my head either....but i think they're fairly closer, a lot closer than hp to kw)
why only 14.5psi?
Very true that one!
Anyone know what the -9 / GTSS sweet spot is....ie, their zone of peak efficiency? I'm guessing it would lie somewhere around the 18 mark as mine go beserk there....
Did he tune it?
what gear is your new dyno run done in? I assume all tuneres use same gear, as max kw at 170kph dosent sound to practical, I pretty much wanna know power in 2nd or 3rd gear at 6k rpm....if thoes sort of graphs are even avalibe? I haven't looked to much into the dyno grqph side of things yet
You cant be serious
Different cars use a different gear on the dyno for a 1:1 drivetrain ratio
Dafaq?
6k rpm at wot and max boost will see the same power no matter what gear it's in
Like i said, I assume, as im not sure, you did not answer my question, let's just say anything over 110 is useless, your dyno shows about 150 kw at 110....like I said not surw how these things work/read
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
