Since i got a copy of all my Dyno's in my Previous R33, i thought i would put up a post of how the car performed to the mods i did. This thread could possibly help people who are in the build of quick rb25's.
BU5TER and STEVE, im pretty sure you guys could ad to this.
When i first bought my car it came with these mods:
Garret GT30 .82 rear housing
Forward facing standard plenum
Bosch 0444 fuel pump and surge and larger fuel lines
Micks Metal craft front mount
Microtech MTX8
MSD Dis 4 ignition system
42mm Turbonetics Deltagate (external Venting)
Custom Exhaust Manfiold
3inch Exhaust with no cat, Just a rear HKS rear muffler.
1st dyno on 17psi it made 330rwhp
2nd dyno with some tuning it made 360rwhp on 21psi
3rd dyno with some more tuning and 26psi it made 387rwhp
(dont have dyno sheets for above as i have lost them)
With 330rwhp 1/4mile time was 13.6 @ 113mph
360rwhp 13.2 @ 116mph
(60fts being in the 2.4's)
Then i got bigger injectors. Changed from Standard to 660cc and fitted a Malpassi fuel pressure reg.
Same set up on 28psi it made 421.2hp. As you can see after 6500rpm there was a major drop off. This engine lasted like this for only a few weeks before it spun a bearing and dropped piston number 6 into the sump. This was on BP Ultimate.
Built a new engine, got the head cleaned up and moddified. This time switched to wiseco pistons from Arias forget pistons and we dropped the compression slightly.
Same set up as above except less compression and different pistons, i made 420.7rwhp. Though it held more power up to past 6500rpm. This tune was done on Optimax.
This set up lasted a month before the turbo shit it self.
I then went out and bought a Trust T88-33d. Rated at either 750 or 850hp (sorry forgot what it was rated at). I also got a new headgasket, and modified the exhaust manifold.
With less timing on 24psi it made 345rwhp. (dis regard the rpm @ the bottom due to it being out by 500-1000rpm). This was on BP Ultimate.
With the above set up i took it to Willowbank in Complete St trim, put the boost down to 20psi due to a leaking exhaust gasket manifold. It went 12.601 @ 120.6*mph with a 2.3 60ft. (gave time slip to new owner).
Once sorted leaking gasket and manifold went back to the track on 24psi, 1st run the intercooler connecting hose shat it self. Though 330ft was .5sec quicker then 12.601 pass and was up 4mph too.
With the same set up on 21psi and leaking exhaust manifold gasket again (now with the new owner) at the Mazfix Dyno day it made 419.2 hp
SOme people say the car was making alot less power then it should due to the tuning, some said my cams were restrictiing it too much.
Hope the above info helps and any one else with Hi Hp rb25 please do post up the steps you have taken
Good luck
harun
  • Replies 40
Thanks heaps for the pretty dyno graphs and pretty expensive parts listings but did the car ever run an 11 ? ! ? ! ?
Dont you think some pretty timeslips would be a better indicator of your ability to give advice on this subject? Oh and for the record, mine is in my profile.
Adrian
Benm wake up to yourself with the fact of Nitto's will instantly make your car quick, what about suspension? camber? clutch? useable power? etc etc and last but not least the driver
Trust me when I say just by using nittos it will help a little but if the car isn't set up right or driver isn't good enough they wont help to much at all as all I ever did was a 1.97 60ft at full power with nittos which sucks
It's very rare that a person will tell a bit of build up history about their car, especially the case that extends over a couple of major changes. Thanks for the info Harun, but as Brett pointed out there's alot more to doing a good time than a big turbo :D
Oh, and not meaning to burst that big bubble of your's Adrian, but nitrous is a different ballgame :(
What? So i didn't run an eleven? You should've told me earlier!!! Damn... Think of the embarassment you could've sav.....wait a minute.... No bubble burst here mate. I did it. And it cost a damn sight less than Haruns build. How does it make my time somehow less significant?
I simply feel it makes a lot more sense for someone to say, "I have run xx.xx sec - here's how to do it." if they have ACTUALLY DONE IT!
You're right about this though - "there's alot more to doing a good time than a big turbo".
Adrian
It's not diminishing the fact you ran a particular time once, it's not the fact that Harun's car didn't run an 11 second pass.
This post shows the development, modifications and results of a few different (and major) changes on one particular vehicle. Granted they would have been expensive, and sharing the knowledge will probably help a few people decide what works and what doesn't - as well as saving resources in repeating the same decisions.
With the somewhat repeatable performance of the engine modifications done to this RB25 it could have been used for drifting, dragging or circuit work. Or could just be shown around so people can gawk in awe at a massive turbo.. there's gotta be something said for show cars 'cause I think the Autosalon boys are raking the cash in. Don't think they would be so successful if there wasn't a market for it?
It is a valuable thread and I totally appreciate how open and un-guarded Harun has been with the information posted.
However, I believe the title of the thread is total cops-arse and not an appropriate way to introduce the valuable information above to potential readers who, (and rightly so) expect to see someones take on the ways and means to producing an eleven second car. Only thing is, he has everything bar the timeslips.
Rather like me saying, "How to produce a 350rwkw RB25!" and then showing you low 11-sec timeslips and video footage of people hanging on inside the car saying, "Woah!" as a means to justify it.
12.6 is a world away from 11.999!
Adrian
Well, since you asked for it, I did manage to run a sub 10 recently with the new turbo and suspension setup in my Skyline. Really hooks up well now, the fronts are off the ground!
Interesting thread :)
I must agree that it was a very curious choice of thread title :Oops:
Also, you state that people have been commenting on the fact that you made less power with the larger T88-33D Turbo... Can I suggest that it might have something to do with your, I quote "modified exhaust manifold"?
I don't think people (in general) really realise the effects of exhaust flow dynamics on turbo operation... You can't just grab your old exhaust manifold, weld on a split flange and whack a T88-33D onto it!!! The T88-33D has a twin scroll exhaust housing, and it is designed to recieve pulsed exhaust gasses through a 6-into-2 exhaust manifold grouping...
I am of course, assuming many things about your setup.
Adrian: what your saying is correct. It did have have the power bar the timeslip. The 1st time i went out the best i could do was a 12.6 @ 120mph (3 runs only). I was only boosting to 20psi due to having a leaking exhaust manifold. A problem which i couldnt clear. The next time i hit the track i blew the Intercooler connector hose pipe (one of the corner bends). I asked every one at the track if they could either let me borrowone for the evening or buy a similar bent hose off them. But to no avail.
The next day i sold the car. I tried to make the new owner take it out to prove that it would do an 11 at approx 12+mph but he ended up having an accident in it and wrote it off.
You can bag, insult what ever you like about the time slip, but (as every one has an excuse) if i did have slicks or Nittos, god dam it would of ran an 11.
Im just trying to help those who seek info on 'what' i did to achieve such power which was capable of an 11sec pass. Sorry for the topic heading as that is what came to my mind when i decided to write this thread.
Merli: The manifold i had was a 6-2 design manifold. I think it was actually working backwards on the GT30. As you can see max boost was reached at very similar revs.
Here is also the other 2 dyno sheets.
BTW: When the car made 345rwhp it was @ 24psi. At the mazfix dyno day it was running less boost with yet again another leaking exhaust manifold and made 419rwhp.
From your first post, I read that you bought the car with a Garrett GT30, and a custom exhaust manifold... I assumed that the exhaust manifold was made for the GT30? But obviously not if it was a 6-2 design!!!
That's extremely interesting... Do you have any pics by any chance?
2rismo - whats your best time without the assistance of the "bottle"?
13.0 on shit rubber. I believe that the Nittos I used to run 11.9 would only have shaved a couple of tenths off the time as without the gas, I'm leaving the line with a lot less power.
Out of interest, the nittos made over half a second difference to my time compared to the rubber I used to run the constant 12.5's with the bottle and the 13.0 without.
As I don't have a timeslip for no bottle/nittos I will say that a 12.7-12.8 is all that would be possible in my car without the bottle.
All of the above with me driving - I don't know why people forget that the driver is needed to pedal the car down the track.
Adrian
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
