Looks like a T2. Watch out for the rods in the VQs. Apparently they start to struggle at 500hp+. That seems to be one of the major issues people face with big hp VQs.
orly? Please tell me what you know?
The rods themselves aren't the issue so much as the rod bolts. They start to stretch once you get near that 400rwhp barrier. But a lot does depend on how hard you are spinning the motor. Apparently Nissan improved the rod bolts in the later model motors, but hey, the motor is apart why not upgrade??
The rods are actually thicker not just the bolts in the HR... the rods a puny and should be upgraded.
So what turbos are compatible with the HKS 3037 rear housing or would you need to upgrade both ? I havnt fitted mine but my engine is being machined this week ready to be full forged built for 600HP, 3037 only get 400-430 so any ideas for upgrade to get 500 ?
Yup. Get Scotty to make you up a new adaptor for the cross over/gate in t3 and get a gt3582 with 1.02 hosing in there
Any ideas on where to get best price for that ? Why adapter needed for the cross over gate? you cant get them in that size? Scotty what price u thinking of to adapt? Honestly u guys reckon 400-420 is not good enough? thats 2x what i got now..
It's all up to you mate! I'm quite happy with what I'm running on the stock block. You might as well strap on what comes with the kit, and just turn it up to max boost. A built motor will take it no worries. Get used to driving that. It's quite a big difference! Probably good to run the motor in with tha too.
The adaptor is a bespoke part of the kit. You'll need something made up to link the manifolds, pipe to the ext gate, and the turbine housing, in a bigger, more free flowing design. It's not an off the shelf part!
Honestly, with a gt3582 think it would be pretty scary! But I'm a massive pussy. I like going round corners too, not just planting it In a straight line.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
