Can anyone help?
I just done the timing belt on my r33 rb25 ive done plenty of them and have never had this problem
I have fuel( fuel pressure, injector pulse, check all fuses), and ive also got spark( tried 3 sets of spark plugs, changed coils) and its still not starting
When i crank it, it doesnt start then i check the plugs again its fouled up
Dry the cylinders dry the spark plugs( or change them)
Try it again still doesnt start
Take the plugs out again fouled again
Take out fuel pump fuse disconnect injectors, still doesnt fire up even though theres fuel in the cylindeds
Disconnect cas still doesnt fire up
Reconnect cas still doesnt fire up
Recheck spark strenght, has plenty
It did start once when it was stripped down to the timing belt with everything connected, THEN ITS FIRED UP with a big puff of smoke then shut it down coz the timing belt was about to fall off, thinking it was fixed i reassembled
After assembling it didnt start, back to square one
Timing marks are spot on
Anyone have the same issue?
There are no vaccum leaks even though it should still start.
At this time its doing my head in bad
Have i misssed something?
Why is it flooding when ive got spark?
Also has a new temp sensor
Anyone help?
Correct Fuel, Spark, Oxygen = Run.
To overcome flooding keep foot flat on accelorator
Signal to spark at the right time was my only other guess.
Some of the Pro's on here will chime in shortly.
ive tried foot flat on the accelorator so many times ive flattened 2 drycell batteries :(
the signal should be right unless ive got a crook cam angel sensor?
damit, maybe ill try check injector pulse and spark at the same time and see what i can get
did you mark cas before you took it off so u can align when you reinstall it? when you say you striped it down then started it you would of taken of the cas to get cam cover off. my 2 cents is you may have put it on out of align hence the reason why when you started it the timing was out causing the big puff off smoke and belt nearly coming off as the belt should be rotating smoothly unless you touched the tensioner.
  • 9 years later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
