Went for a charity car cruise yesterday..car had been very rarely not wanting to go into gear (i.e i'd have the clutch all the way in and it wouldn't select)
Didn't think much of it as it would just be a little grind when trying to shift quickly, when I Went slower it went in.
Went to do a 3 point turn in a car park, put clutch down to the floor....no pressure.
Pushed the car into a parking spot, saw clutch fluid all over the ground.
Spoken to a few of my mechanic mates they all think it's the slave cylinder that has failed, does anyone have any idea? Or seen this before?
Car has a HKS Twin Plate clutch.
Thanks!
https://www.sau.com.au/forums/topic/403865-clutch-slave-cylinder-maybe-r32-gtr/
  • Replies 50
Was your reservoir empty? If its the slave you"ll see fluid leaking. Fill the reservoir and watch it while someone pushes on the pedal (and look elsewhere on the line for leaks) Get a torch and look under the clutch pedal for interior leaks from the M/C and then under the bonnet.
Yes, when I checked it at the time, it was empty.
Ok thanks, I will give that a try - in the mean time should I shop around for a slave cylinder?
There was fluid all over the ground in the initial spot, and again when I moved the car when the tow truck came.
Edited by ls128
Yes, buy a slave. Also buy a master, as it will also be old and ready to die. Also, buy a braided hose if you're not feeling too poor. You will appreciate the feel.
+11ty. This is excellent advice.
It's definitely the slave, had a proper look under the car tonight. For the extra 15 dollars I will probably go to JustJap as it is very very very local for me, Not sure if I will do the master, as that makes it a much bigger job then just slave, correct?
"Keep the feeling"?
It's a twin plate..its the heaviest clutch I have ever felt!
Just jap has slave for 115, master is 300..braided clutch hose is about 150.
I wasn't referring to clutch feeling. Read between the lines (Toyota genuine parts - keep the feeling)
Heh yeah, I realised that about an hour after I replied and was re-reading the post.
Got a genuine nissan slave for $105. Swapping it out tomorrow morning and bleeding. lets hope!
  • 4 weeks later...
So, Swapped Slave cylinder, Master cylinder - now when the car is in gear, and the clutch all the way down to the ground, car will creep forward like the clutch isn't engaged.. looks like i'm up for a new clutch :(
Disagree - what you have still sounds like its not fully disengaged. My guess is there's still air in hydraulic system. I'm told it can be a bitch to bleed the clutch hydraulics, especially the "dampener box", or whatever its called.
Ok abit more info:
Saturday, put a new master cylinder on. Adjusted the master cylinder inside the cabin (almost all the way, only 1-2mm of thread left) Worked for about 20 minutes of driving, then started doing the same issue. Often won't go into first, or reverse. Start the car in first, with the clutch fully in and the car will crawl forward like it is in gear (despite the clutch being foot to the floor.
System was gravity bled and pump bled for an hour. in total we bled it 3-4 times.
Spoke to a mechanic friend and he says that he had a similar issue and when he pulled his clutch out several of the clutch springs had come loose.
Suggest you grab someone who knows how to adjust the push rod on the master cylinder.
No way is it right if you're down to the last threads ????????
Have you any free travel at all?
Without free travel the master cylinder will never prime correctly.
Did anyone check the booster unit.
We adjusted it more because before adjusting the rod it still wasn't giving enough pressure - my mechanic had a look and he said there was enough free travel.
Check booster unit as in how? We didn't touch the adjustment rod inside the booster unit.
Where did you bleed it from? If its just from the slave, then that I dont think it will be effective. Actually, i cant really see the point of a bleeder on the slave....
Yeah from the slave..after we dropped all the fluid out and put the new master cylinder on. We spent a fair bit of time making sure all the air was out of the system..
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
