I don't really know, I havnt heard back from the guy I baught them off
Havnt touched the old 33 for a few days as I've just moved to ballarat
It got it's first big drive from albury to ballarat 450 km and didn't miss a beat
Looking into ideas for the wide rear end still do I buy a kit or flare
Anyways near future should bring answers
Are they a reliable setup
Stock rb25 on e85 300-350kw as reliable as it gets, easiest cheapest option. Go the 30 if you want moretorque but personally i cant fault mystock 25 with 320 in my drift car.
I was thinking that
I baught a set of 1000 cc injectors and was planning on tuning it to e85 and leaving it at that until it pops
In still building an engine but it but it will be done over the rest of the year so it won't destroy the pocket
Time to attempt the gaurd rolling today let's see how it goes :)
I was thinking that
Ye thats best way drop a stock 25 in get the car going then take your time build whatever you want. E85 good tune , change oil after every track day it will last ages, mines been going for 2.5years so far on e85 and a year on 98 beforethat.
Note that that's not actual ride height I just popes the coilovers put to see how the wheel tucked
I think it will do for now after I toutch up the paint and il put a wide body on it when the cage is in and I repaing the shell
Shows good maintenance pays off hey!
Im hoping mine will last until the end of the year
RHD have widened rear fenders, think from memory 1200 shipped but I might be wrong. Same as standard but flared. Look good. Think D Max also do a widened rear pair too.
1200 that's big coin you can get gtr style wide guards in melb for under 500
Really? Where from mate? Not doubting you , just interested for my own build! PM if you don't wanna post in here.
I'm guessing like anything cheap means lower quality
For for what Im doing that's all il need
Something that's relatively cheap also makes it Easyer on the pocket once
You brake it as if I broke a $1200 gaurd by kissing the wall my mrs would be chasing me down
the main straight with the tyre iron
Ah yeah I've seen those ones! I almost bought them a few months ago, but was unsure of how they'd line up, I'd they'd need filler, and lots of work to line up!
If you get them let us know how they fit!
  • 3 months later...
Haha just saw your reply...few months later lol!
Did you en up getting these fitted? Or weren't they any good?
Guess what I was getting at with lots of work is that often by using cheaper parts lots of modification is needed to fit them. I was lucky enough to get my hands on a genuine 400r front, no modification was needed at all. Lined up on a dummy fit first time! So yeah, the price difference can be a big thing, but most times I'd rather spend the extra coin (if I can afford to) and reduce the labour/fitting times. In my opinion.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
