Take starter solonoid off for the rhs top bolt, dump off for lhs top bolt, for the one right in the middle undo the gearbox mount and let the drop the box as much as you can then get a long ass extension peice get it onto the bolt and rattle gun it off.
Doing this for the 10th time ATM, :unsure: 3 x extentions with the box bolted up the motor ( with all the other bolts at least ) and just hanging down, slide extensions along the top of box and rachet from back of box ( shine a torch along top to see bolts ) easy .... yeah with one of those semi-balls on end extension .
  • 3 weeks later...
