Seano350GT Posted July 10, 2012 Share Posted July 10, 2012 I have stock 03 Coupe headlights (appear to be Halogen as it is sort of a yellowish colour) and my right light is burnt out and left starting to go as well. I'm going to purchase these HID aftermarket lights - http://www.importmonster.com.au/view?url=http://page17.auctions.yahoo.co.jp/jp/auction/v258400887&thumb=http://auctions.c.yimg.jp/f42batchimg.auctions.yahoo.co.jp/users/7/2/8/7/crystaleye78-thumb-1305511072260843.jpg&title=V35 Now i'm not after any comments about quality or what-not, all i need to know is if these new HID lights will plug straight in even though my stock lights AREN'T HID. Feedback would be greatly appreciate as i'm having next to no luck getting answers if these will work or not, Thanks Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/ Share on other sites More sharing options...
89CAL Posted July 10, 2012 Share Posted July 10, 2012 (edited) EDIT: Just re-read the translate and it says: HID low beam unit will be of genuine use So to me it sounds like you need to use the Standard HID's from your old light in this one. Reading further down sort of confirms that but I wont get into it anymore So basically by the sounds of it, it should all plug in and you can continue to use Halogen globes with it, or just buy a HID conversion kit for it Edited July 10, 2012 by 89CAL Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6437258 Share on other sites More sharing options...
R6n350GT Posted July 10, 2012 Share Posted July 10, 2012 None of the ones in the group buy had HID kits... You will need to use the ones off you existing set, if your existing set doesnt have them then they are $100 each ballast + ignitor cable from USA ex postage Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6437272 Share on other sites More sharing options...
Seano350GT Posted July 10, 2012 Author Share Posted July 10, 2012 EDIT: Just re-read the translate and it says: HID low beam unit will be of genuine use So to me it sounds like you need to use the Standard HID's from your old light in this one. Reading further down sort of confirms that but I wont get into it anymore So basically by the sounds of it, it should all plug in and you can continue to use Halogen globes with it, or just buy a HID conversion kit for it None of the ones in the group buy had HID kits... You will need to use the ones off you existing set, if your existing set doesnt have them then they are $100 each ballast + ignitor cable from USA ex postage I think i will spend the extra money and buy the full HID kit, i just don't know if there's many variations of them or if there is just a regular HID kit i can use to make all of this work. I just hope if i do spend ~$700 that ALL of the functions are going to work IE. indicators, low beam, high beam, the LED strip on the side with parkers. Fingers crossed.. i will do more research though before buying. Thanks for your help Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6437417 Share on other sites More sharing options...
Haino Posted July 13, 2012 Share Posted July 13, 2012 Well you could go with them but proper HID's require a conversion kit, which is simply a globe connected to wires connected to a ballast (power booster outlet thingy) connected to wires which plug into ur stock wires running to the power, this means a complete change in shit, I had to pull the stock globes out and corresponding wires, cut a 20mm Hole in the back of the low beam cap that screws into the back of the headlight and run the new HID globe n wires through it, which then connects to the ballest which u mount onto the engine bay somewhere, dw you get mounting brackets, then plug into the ground wires etc. running to the power source. So if u want to go proper HID's in a V35 coupe, ur gonna need to cut a hole in the headlight cap, the old plugs still sit there so if need to u can just plug in the stock shit again but if u take the head light out and look at the back, ull know what I mean, to run the extra cables for HID's youll need to cut a hole, but if u want to just change the colour to a white/blue bulb n use stock system thts fine, proper HID's need a conversion kit with ballasts, oh and mounting them in a B***H, I just cable tyed them as best I could haha Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443151 Share on other sites More sharing options...
Seano350GT Posted July 13, 2012 Author Share Posted July 13, 2012 I think i'm having a change in heart. If i went for the 06 G35 Projector headlights would it be possible to aim them far enough down/left to make them like our RHD lights? Every JDM set i find seems to be shit quality and i've heard really good things about the G35 Projectors. UNLESS the 06 V35 Coupe comes with projectors the same as the G35 ones but RHD? Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443232 Share on other sites More sharing options...
Seano350GT Posted July 13, 2012 Author Share Posted July 13, 2012 Did just find out that the 06 V35 Coupe has stock bi-xenon projectors. Now i just need to find somewhere to source them from. Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443236 Share on other sites More sharing options...
R6n350GT Posted July 13, 2012 Share Posted July 13, 2012 just buy USDM, you cant even tell they aim to the left... even if they do a little, who cares, i get blinded by all these ebay hid kits all the time, ppl are used to it Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443288 Share on other sites More sharing options...
Seano350GT Posted July 13, 2012 Author Share Posted July 13, 2012 Yeah f**k it, all these other lights i've found look okay but seem to be way too much of a f**k around to install and swap out for the old ones so i'm going to pull the trigger and go for it. I know how to aim the lights anyway and i'm sure they aren't THAT far off considering both V35/G35 have the same front so why would the lights be facing the complete opposite way? Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443292 Share on other sites More sharing options...
t5iv Posted July 14, 2012 Share Posted July 14, 2012 The lights face different directions so that they light up the appropriate side of the road. However, BMW headlights have to be borderline illegal! How many times have you been blinded by those stupid headlights? It's not mercs or audis, damn BMWs!!! Grrr rage Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443303 Share on other sites More sharing options...
Seano350GT Posted July 14, 2012 Author Share Posted July 14, 2012 Surely you can aim them to suit our driving laws or near close enough though? Yes! too right, i have noticed that. It's quite annoying so i don't want my lights to be like that Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443314 Share on other sites More sharing options...
Seano350GT Posted July 14, 2012 Author Share Posted July 14, 2012 Totals up to being $690 for the 06 G35 Projector headlights shipped to my door. Everything else is pretty much around that price including shipping too. Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443320 Share on other sites More sharing options...
sonicii Posted July 14, 2012 Share Posted July 14, 2012 it isn't a matter of aiming, it is an issue of the shape of the light pattern. RHD headlights have a light pattern that 'kicks up' on the left to properly light the left side of the road. LHD light pattern kicks up on the right.. straight into the face of oncomming drivers.. if you tried to adjust a LHD head light low enough to stop it blinding oncomming drivers, the main light pattern would be so low that you wouldn't be able to see much more than 2 M in front of your car! I have head stories of people dismantling the projector headlight and removing part of the reflector to make the light pattern flat, which I imagine would then be legal. no idea if you can do this with G35 headlights though. You can be defected for using LHD headlights here. besides the inconsiderate issue. Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443337 Share on other sites More sharing options...
Seano350GT Posted July 14, 2012 Author Share Posted July 14, 2012 it isn't a matter of aiming, it is an issue of the shape of the light pattern. RHD headlights have a light pattern that 'kicks up' on the left to properly light the left side of the road. LHD light pattern kicks up on the right.. straight into the face of oncomming drivers.. if you tried to adjust a LHD head light low enough to stop it blinding oncomming drivers, the main light pattern would be so low that you wouldn't be able to see much more than 2 M in front of your car! I have head stories of people dismantling the projector headlight and removing part of the reflector to make the light pattern flat, which I imagine would then be legal. no idea if you can do this with G35 headlights though. You can be defected for using LHD headlights here. besides the inconsiderate issue. Thanks for the input mate, i'm getting in contact with Import Monster to get them to source me some JDM projectors that plug straight in. Literally next to no luck finding these lights online though it's stupid. Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443365 Share on other sites More sharing options...
Seano350GT Posted July 14, 2012 Author Share Posted July 14, 2012 Here are my current lights - You can see the bulb has fallen off Here is the engraving "DOT 1D2R" what does this mean? Need some feedback on what type these are, HID, Xenon, Halogen? I don't know! Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6443642 Share on other sites More sharing options...
sonicii Posted July 15, 2012 Share Posted July 15, 2012 D2R is the type of HID light used by the manufacturer for low beam. if you car was properly complied after import, the HIDs would have been removed and replaced with halogen lamps. looks like the low beam reflector has falled off on yours, but I can't really see the actual lamp properly. The High beam and fog lamp section is a halogen lamp from the factory. the easiest way to tell if you have HIDs is to watch them when you turn them on, they generally take a few seconds to reach full brightness and tend to be a bit bluish until they have properly warmed up. Halogens are generally at at full brightness almost immedeatly (less than 1 second). Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6444396 Share on other sites More sharing options...
Seano350GT Posted July 15, 2012 Author Share Posted July 15, 2012 D2R is the type of HID light used by the manufacturer for low beam. if you car was properly complied after import, the HIDs would have been removed and replaced with halogen lamps. looks like the low beam reflector has falled off on yours, but I can't really see the actual lamp properly. The High beam and fog lamp section is a halogen lamp from the factory. the easiest way to tell if you have HIDs is to watch them when you turn them on, they generally take a few seconds to reach full brightness and tend to be a bit bluish until they have properly warmed up. Halogens are generally at at full brightness almost immedeatly (less than 1 second). Yeah the reflector has fallen off how am i meant to buy a new one of those? I must have halogen's then because these come on instantly no delay at all. Cheers for the reply Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6444447 Share on other sites More sharing options...
xj265 Posted July 15, 2012 Share Posted July 15, 2012 Have you seen these? http://page.auctions.yahoo.co.jp/jp/auction/156802948 Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6444510 Share on other sites More sharing options...
Seano350GT Posted July 15, 2012 Author Share Posted July 15, 2012 Have you seen these? http://page.auctions...ction/156802948 Are they RHD? And what price AUD?? Very interested Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6444685 Share on other sites More sharing options...
xj265 Posted July 15, 2012 Share Posted July 15, 2012 Well it states they are made in Japan so you would think RHD I asked a Japanese friend to ask 'if they are for RHD or LHD car' and the seller replied with 'they are for RHD and LHD car'..........which doesn't help what so ever Link to comment https://www.sau.com.au/forums/topic/404399-hid-headlight-swap/#findComment-6444824 Share on other sites More sharing options...
