Hey guys I am new here and fairly new with turbo modifications, blow off valves .
I Have a Nissan Skyline r33 25GTS-T 1995 completely stock besides a pod filter and cosmetic upgrades.
When changing gears it goes Vvruum tushh , but I want it to do the classic awesome sound Vrumm tush tush tush ...
Sorry if I sound silly hard to explain , how can I get this ? Do I need to boost my car ? Upgrade blow off valve ?
Also my blow off valve is plumb back
Don't want any silly comments please just after some help heard you guys are good..
I'm after that like flutter or "dosing " sound ... Currently it just makes a one release of air pressure type sound ..
As I said I am new to turbo charged upgrades
Thanks in advance I will have a look on YouTube if that helps ...
yeah you want a really good BOV...make sure you spend alot of money on it cause the girls wont show you their boobs if you got a cheap one
this ones dope
http://www.ebay.com....=item2ec00ed88a
Didn't realize blow of valves are that dear ... Do you need something this expensive ? I'm not looking at making it like race ..
Upgrades I was looking at was a HDI intercooler and a 3 " catback hi flow exhaust with a canon and possibly a boost controller
I was being VERY simple with my instructions.
Someone knowledgeable explain it.
Without starting a BOV vs. No BOV debate.
Was not trying to like insult you just from what I have heard that you need it and it's there for a reason , without it the pressure builds up wears out the turbo faster and puts more pressure on intercooler ect ect
I.
Fucking.
Dislike.
School.
Holidays.
Mate I don't go to school I am 22 and work at the mines , like I said before I am new to turbo charged modifications and was told this site the guys here are helpful . And I hate school holidays to , far to busy for when I am off work, everyone drives like 10 under the limit wtf must be the teachers
People here are EXTREMELY helpful. They just get over the same threads being started countless times, asking the same questions over and over again, when this thread has been covered 2000 times since the site started..
To answer you, cheapest way, block the BOV off. Expensive way, buy a new BOV and tighten it up so it doesnt open under lower boost shifts.
Turbo damage debatable. With the stock, ECU, the drive ability will suffer.
Cue R31Nismoid's pre written Thread lock post soon?
Yeah I understand that would happen ..
Thanks for that
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
