Hey all,
Long time since Ive posted here. Anyway just looking to quieten down my car a little. At the moment its got the HKS Silent Hi Power exhaust(the one without the muffler), and its far from silent. Its a 3.5" exhaust pretty much just a long tube to a canon. Ive got another exhaust here which is the 3" Nismo exhaust which has a mid muffler and also the biggest rear muffler Ive ever seen.
If I swap these exhausts out will I notice a big drop in performance? I don't really do anything with the car which needs performance all the time. Just a daily driver to and from work and when out with the mrs. I figured since I granny drive the car I should keep her quiet(after seeing the ACA shit on TV and how cops are going to be cracking down on defective cars and mainly noisy cars, the least attention we attract the better).
I can live with power loss but if its going to cause my turbo to heat up much more rapidly which will raise intake temps and potentially cause det, that is what I can't live with..... We all know how strict HG is about high flowing exhausts with their turbos(SS2).
Any input? Are those nismo exhausts rubbish? Last I heard it on my car, I couldn't even hear the thing at idle and since the stock exhaust isn't even enough to stay legal, this one is quiet enough not to hopefully awake sleepy eyes when I finish those late shifts.
Hey Sarge,
What modifications have you got and how hard for how long do you run your Skyline?
Nismo is one of the best quality exhausts.
I dont beleive you will get too much of a drop in performance, the noise is alot quieter.
It's only going to cause a drop in power if it is a restriction. Which I doubt it will be. You mentioned the SS2, is that what you are running? At SS2 power levels, a 3" exhaust should be plenty. Just make sure it is a true 3", a lot of Jap exhaust systems have step-downs to around 2.5-2.75" which may well be a restriction. Not sure if the Nismo ones do this.
if its quiet it will most likely have a restrictor, when i put my old system on after it had a loud system, the silencer was having effects cause the car was running hotter, not pulling so hard and a couple of times i heard it knocking.. so you may need timing taken out.
I think TiTAN's statement is correct, its when you find a quiet exhaust with no mufflers(low profile crap you see online) which can shut the sound up but poses a massive restriction. The size of the rear muffler is f**king huge, if you've seen the Nismo exhaust you'll know what I mean. If you haven't its about two times the size of a HKS canon. The mid muffler is nice and big too. The pipes are full 3" all the way to the back. My old HKS was 3" then became 3.5" after the resonator in the middle.
Just fitted on the Nismo, honestly doesn't sound bad at all. It loses that tough raspy sound of the HKS but what I'm left with is a very nice quiet idle and a clean RB note. Only issue now is the damn gasket between the cat and the cat back is shaggered(its the multi plate copper thing). When backing off I can hear the plates flapping around so gonna need to replace it.
My car is all bolt ons(injectors, turbo, dump, ecu etc) for 255rwkw. Most of my drives are on average 15 minutes long. Sometimes the odd 40 minute drive. Never really take it anywhere. When summer rolls by Ill throw the HKS back on if the temperatures are an issue.
Edited by SargeRX8
Main problem with the Nismo 3" catback is the weight (good mufflers!), it flows pretty well.
You'll notice that the exhaust note wakes up after ~4000rpm so it's still good soundwise.
Performance wise you will take a hit from reducing ID of the exhaust, but shouldn't be to noticeable on your power output.
For reference I had that exhaust on my 32R for 4 years while it was daily driven, was a lucky charm with police I reckon because I never got any grief :)
Any exhaust system thats going to be quiet, is going to weigh a fair bit... that's just how it works.
You could add a better muffler to the 3.5" system if you wanted. That would most certainly help, two = super quiet.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
