so is this the definitive cause? would it also be leaks as suggested?
Im gonna give both the aac valve and the cold start control valve a good clean tomorrow, ill report back if i find any changes but so far from what i have researched, it seems to be the cure for the cold start up problems every morning. Im gonna clean the o2 sensors as well. Hopefully it makes a difference.
cheers awaiting your post
Hmmm...every morning same thing with me....Idles low when I first start , sputters and sometimes dies....If I blip the throttle slightly it seems to "catch" and hold its revs. I plan to put a remote start in soon so this is quite annoying. Lets hope we find the culprit quickly and if we do...then lets get this as a sticky...
Well I cleaned the aac valve. It felt better for sure but it still died, I havn't driven the car for a couple of days so it was prob going to start shit anyway, So will see tomorrow for sure if it worked or not.
Cheers for the report dyl33, ive been a little busy past few days, ill clean the aac valve out tonight and report back if i see any difference. But still its good to see that it made a bit of difference. I started my car this morning and it didnt die this time, I left it outside in the cold over night for the first time in a few months instead of in the garage, it didnt struggle as much to start which is odd, but maybe that's just a one off coincidence. Edited by Deza3000
Ive just finished cleaning the aac valve and it starts up so much better, just went for a long drive. The start up was almost instant, very smooth and quieter idle than before, however thats only in the period of 5 hours since it was last turned on. I will let you guys know how it starts tomorrow morning, hoping for the best, but other than that so far so good!
well its just gotten worse for me. was extremely cold this morning , started it up , revs started to drop , so i blipped the throttle slightly , when i took my foot of it started to drop again. this is the first time its happened. I had to rev it a bit higher for it to "catch" and hold steady...
Will be looking at my aac and following this thread closely
Edited by tripsteady
Hey guys, its been 2 days since i last started the car, started the car up this morning, and i gotta say, it started up absolutely brilliant. The revs started off low for not even a millisecond and it was pretty much 100%. No lumpyness, no idle problems, no stalling. Cleaning the aac valve pretty much worked for me. i give it 9/10 points. Just a heads up i didnt just clean the aac valve, but i cleaned the intake where the aac valve connects too, as well as the pipings and all surrounding areas, spent 3 hours cleaning it. Used a tooth brush to scrub off all the dirt etcc. Hopefully it works for you guys too, i also turned the idle control valve fully open to clean out the gunk, then i returned it to its original postion, i also used a vaccum cleaner and sucked any stray dust that was present in the intake and in the aac valve. Other than that, i pretty much followed the rest of the diy guide.
cheers for that , will definitely give this a go and post results
Hmmm, Why didn't it work for me? Was I suppose to clean inside the aac solenoid (the brown plug)?
Yea you were actually, also try turning the throttle a little, open it up a bit more
It must be the cold start valve under the plenum, from what ive seen around the skyline forums a lot of people are having this problem, how ever there still hasn't been 100% guaranteed solution to why it has been happening. No one really had bothered to clean the cold start valve under the plenum. A few people with turbo'd skyilnes cold start problems were due to aftermarket bovs etc...I dont think it would be a fuel injector problem cause then you would start to see symptoms while driving as well. And yes that was the same case with me too, when i tickled the throttle the motor would stabilize , thats why i opened up my aac valves idle position all the way so it does a slight throttle when starting up, eliminating the problem. However this is at the cost of ruining my idle position, now it idles at 950 rpm as opposed to 700. Ill have to give the cold start valve a shot by cleaning that, ill have to get done by the mechanic.
Just an update, ive done a little experiment, i returned the throttle to its original position on the aac valve and turned on the car, but this time what i did was i turned the key for a fraction of a second longer than usual, and the car started up perfectly. Basically just hold the key in the ignition position for 0.5 to 1 second longer and it should start up normal. My theory is, the spark isnt fully igniting the fuel because the battery dies over night explaining why it happens every morning, resulting in the car to struggle on what little spark it was given to start up the motor. This is just my theory, but you guys should give it a shot, turn it on for a fraction of a second longer. Hope it works!
worth a try for you guys but ive put an optima yellow top in recently and there is no way the battery has anything to do with this problem
mentioned it to Paden when I dropped my car off for the 100 thou service this morning , lets see what he comes up with.
Today I held the key in the start position for 1 second longer , And it fired up perfect... What the hell
So it worked for you too aye? Well i guess its good news we found the cure, but i dont understand why it needs that extra second. Atleast i wont have the dodgy start ups anymore. And i guess that aac valve didnt really do much in the end. Only way the aac valve would help the start up problem was if you increased the idle speed, which was getting rather annoying, hence why i returned it back to normal and done this little experiment ;p. Glad it worked your you as well!
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
