CAR IS IN SA
Im putting this up for 8K cash only, swaps will be considered for cars worth 9k or less with cash adjustment
For sale R34 GTT Manual Turbo
77,000kms
Stock except for wheels
Enkei rpf1s on rear 17X9.5s
SSR Tanabes on front 17X8s
Brand new tyres: Fed 595 on front, westlakes on rear all 235/45/17
Enkei lightweight wheelnuts/locknuts
Interior in very good condition, good aftermarket sound system
Engine runs perfectly, no engine lights, no running rich ect..
Gearbox is smooth and tight
All gauges and sensors work
Very nice to drive
Problems
Paint is not very good, there are a few dents and scratches ect. Front bar colour is different to rest of car.
Has some power steering chattering, and needs a wheel alignment and steering sorted
Car doesn’t have aircon
Has a hicas lock bar so will need 4 wheel allignment
This car is far from perfect having previously sustaining a crash in the front, however with a little more work it would be a real nice car; I have factored the problems into the price. Do not waste my time if you are expecting a perfect car.
$13,000
now $9k
has rego
what do you mean price is factored in? what was the quote for repairs?
is the car currently registered or written off and need inspection?
+1
Edited by jukic.j
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
