It doesn't look like this anymore..... a couple of hours stripping everything off and she's almost naked!
A for sale thread of all the bits and pieces will be up soon.
Pm me if there's anything in particular you want....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
