Flux Capacitor?
LOL, will power cycle it so I can rule it out.
I know the tie rods aren't great and the front suspension is squeaking over speed bumps so shagged out bushes does seem a pretty logical explanation.
Can someone point me in the right direction for new ones?
Also the car is under 3 month statutory warranty, would new suspension bushes be covered? My inclination is that they wouldn't....
Edited by 180Shauny
If it isnt the tyres I would say the main castor arm bush is shagged, fairly common fault on these barges. Not really something you can check on the side of the road though.
yeah you can; grab the castor arm, give it a yank
  • 3 months later...
An update to this issue, I was doing a tight turn at low speed in a car park yesterday and it started shuddering. I then realised I'd bumped the Synchro button, switched it off, no shudder.
Seems the problem may be in the front drivetrain, any ideas? Also discovered a power steering fluid leak last night, yay more money to spend!
Different wear. How do they look? It doesn't take much to cause issues, a couple of mm can do it.
Perhaps the attessa fluid?
I can't think of much else, yours isn't LSD rear is it?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
