Flux Capacitor?
LOL, will power cycle it so I can rule it out.
I know the tie rods aren't great and the front suspension is squeaking over speed bumps so shagged out bushes does seem a pretty logical explanation.
Can someone point me in the right direction for new ones?
Also the car is under 3 month statutory warranty, would new suspension bushes be covered? My inclination is that they wouldn't....
Edited by 180Shauny
If it isnt the tyres I would say the main castor arm bush is shagged, fairly common fault on these barges. Not really something you can check on the side of the road though.
yeah you can; grab the castor arm, give it a yank
  • 3 months later...
An update to this issue, I was doing a tight turn at low speed in a car park yesterday and it started shuddering. I then realised I'd bumped the Synchro button, switched it off, no shudder.
Seems the problem may be in the front drivetrain, any ideas? Also discovered a power steering fluid leak last night, yay more money to spend!
Different wear. How do they look? It doesn't take much to cause issues, a couple of mm can do it.
Perhaps the attessa fluid?
I can't think of much else, yours isn't LSD rear is it?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
