Flux Capacitor?
LOL, will power cycle it so I can rule it out.
I know the tie rods aren't great and the front suspension is squeaking over speed bumps so shagged out bushes does seem a pretty logical explanation.
Can someone point me in the right direction for new ones?
Also the car is under 3 month statutory warranty, would new suspension bushes be covered? My inclination is that they wouldn't....
Edited by 180Shauny
If it isnt the tyres I would say the main castor arm bush is shagged, fairly common fault on these barges. Not really something you can check on the side of the road though.
yeah you can; grab the castor arm, give it a yank
  • 3 months later...
An update to this issue, I was doing a tight turn at low speed in a car park yesterday and it started shuddering. I then realised I'd bumped the Synchro button, switched it off, no shudder.
Seems the problem may be in the front drivetrain, any ideas? Also discovered a power steering fluid leak last night, yay more money to spend!
Different wear. How do they look? It doesn't take much to cause issues, a couple of mm can do it.
Perhaps the attessa fluid?
I can't think of much else, yours isn't LSD rear is it?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
