Whats the best fix gents, geezer I know has a cross threaded spark plug which may be causing a miss fire, it's on the 6th cylinder so it's a pain int the arse to get too, but can this be tapped or re plugged?
https://www.sau.com.au/forums/topic/405141-cross-threaded-spark-plug-hole/
Just do what you did in europe then
tools are in Europe hence why he need's somewhere who can do it.............. and a generator is a little different to a skyline engine. if you feck the gen up nobody cares, i break his skyline he will cry!
anyone ever had it done by a mech?
to be honest even if i could borrow the tools i wouldn't feel confident.... we used to fill the hole with a rag forced into the top of the cylinder with the piston at tdc, once it was tapped we would vacuum out, remove the rag, vacuum again, then use a tiny fiber optic camera with a light to look for the fillings. it used to work. anyone confident enough to do this around the peninsula?
If you grease up the tap it should hold most of the chips in the flute, I'm guessing the thread only needs a cleanup anyway, as if the plug were fully cross threaded it would need to be removed and helicoiled.
A vacuum cleaner with a length of hose attached sounds like the go for cleaning out the bore, and those snake cameras are only $100 these days.
I doubt that is the cause of the missfire though...
Ok, heres the best & EASIEST way to do it WITHOUT getting anything in the cylinder. I work in heavy engineering, & am an engineer. Showed an apprentice this trick yesterday after he f**ked an oil gallery plug hole on an installed crankshaft. (7,042 c.i. V12). Compressed air is required.
1. Bar engine over till intake valves for cylinder are open, exhaust valves closed.
2. Find a suitable vaccuum port on inlet manifold, try to clamp other hoses/passages temporaily.
3. Rig up an air line attachment to the port with an inline valve to regulate supplied air to the cylinder.
4. Remove spark plug.
5. Slowly open valve. You should be able to feel air blowing out of the spark plug hole.
6. Run tap DRY into hole & slowly re-tap thread. All filings will be carried out with the air, so watch your eyes!
might take alittle bit depending on how bad the thread is. Using this method has worked EVERYTIME WITHOUT FAIL!!!!!!!!!
it doesn't seem to bad. its at a very slight angle, towards the front of the engine, i say i think its misfiring but not actually sure car drives perfectly, but we changed the knackered coil packs, and the one on that spark plug was cracked, and it seemed like it was because of the angle it was attached.its not a major issue, but its just gonna cost a fair bit if it keeps cracking coils.
cheers for all the input fellas, we just really dont have the tools or equipment to do it ourselves. rather pay out 100 bucks or so rather than having to forkout for a new head/gasket/ancillarys etc.
shame your in sydney boss, otherwise we would be round with some beer for ya in exchange!
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
