i think it really comes down what your block looks like - if you bores are fine, keep the stock pistons - just replace the rings etc. But if you got scarring and sh*t on the bore, then you may want consider a bore out to 86.5mm which will mean A/m pistons.
You've mentioned you want to keep it reliable - although it may cost a bit more, doing a little extra then what your've got listed should give you a fairly bullet proof engine.
are you pulling the engine out before you sent it to the shop or are you getting the workshop to do everything?
  • Replies 90
This thread has gone from bad to worse.
Now it's up to not using .20thou pistons to save money? Bore and hone is $180!!!! Oversized pistons are the same cost as stock sized.
Would you like to do it once correctly and have it last, or skimp on vital things and be wondering in 6 months why it's died again?
Just save your coin and take it to an RB shop who knows what they're doing, let them do what's needed and then pay the bill.
Edit: not trying to sound like an ass, just seen this happen before.....a lot
Also heres something to consider; there's now going to be tiny bits of bearing material throughout the oil, all of the oil.
So anywhere the oil goes (engine of course but oil cooler too), needs to be cleaned out properly. So cooler core and the part you may not have thought of yet, the head. A head service isn't a big deal while the engine is apart but it's like anything and not free.
If you just pull the engine out, pull the sump off, and try to swap bearings (you'll have to pull the crank out to machine it), then put it all back together the problem is you don't know how much bearing material is in the head waiting to wreck your day soon.
I'm happy to help as I have for others in this position but not if you won't allow it to be done properly the first time.
I am getting a Nissan N1 pump for my build.
But that's just me staying with Nissan parts.
And it can handle the power you want for you build and a lot more if you decide to tune up for more power.
If you have the money go the Tomei or Nitto but as you mentioned cash is a slight issue atm so just go the N1. They are a good pump regardless of some of the things that you might read on the forum about them.
For your power goals it will be perfect and give you room to play with if you decide to down the track.
Ps dont forget your oil restrictor ! :)
I know of at least of 3 people running unmodified N1's in their big single Rb26 drift cars that see regular limiter bashing at high 300 - low 400kw and they do just fine.
Too many people are too quick to bag them out imo.
The car is getting
CP Pistons
Manly Turbo tough rods 1000hp
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
Tomei Oil restrictor
ACL bearings
studs
Tomei valve springs
Gates racing timeing belt kit
Gasket kit
probs more that i cant think of but thats the main guts of it. i will see how i go when it gets closer to it, its around about 1k more for the nitto pump if i can strech it out then ill bag that or go the N1 if i cant.
Edited by T4NK
Only alterations might be Nismo belt and Nitto pump.
Ever seen a cutaway comparison of a N1 pump Vs Nitto?
I have an N1 oil pump. It's behaving itself.
My son's VS2 Nur has had its N1 pump changed to a Nitto just for precautionary reasons (by the previous owner).
My $0.02 - I think alot of it comes done to who builds the engine and how anal they are about bearing/general clearences/tolerences. I beleive Its the shock loading caused by excissive clearence between the colour and gears that cause the pumps to fatique crack and fail...This can happen in all pumps, but its more prenounced in the n1's & stockers due to the relative strength of the material (sintered metal vs say en24(or there abouts) for the nitto). One day, i'll sit down and run an FEA analyse on a few of the pump designs to show the weak points in the designs.
However, IMOH all pumps will work in the hands of a compentent engine builder. The tomei/nitto just offer an additional safety factor.
If you do go down the tomie/nitto route, i strongly recommend getting a sump extension to 8L and baffels installed to prevent oil starvation due to the higher pump flow rate.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
