  • Replies 120
id like ta come my skys not as flashy as some of the others ( few shopping trolleys an s@#$ but you know its a daily driver) im sposed ta be down south absailin if not id love the op ta meet a few peeps even if cherry red (my car ) aint in the shoot
OK. I have finally got off the pot, stopped p#ssing around the edges, playing the camel outside the tent :spcow: (!), standing outside looking through the window, etc, etc. Having filled the form in weeks ago, I have just sent it to Zanda. :type: Now I understand that there may well be no more room for such a late-comer as me in the photo-shoot, and the car is fairly stock, needs a wash, etc, but I wouldn't mind coming down with the kids to have a gander anyway. Maybe I could even pay my membership fee, if the receipts book is handy!
Let me know if there is room?
Meanwhile, for those of you getting a little wound up about all this, here is a cool smilie! :wizard:
Cheers.
If your a member then feel free to come down, will be a good social situation:D
The list of people I have coming so far is:
25GTT
Skyzerr33
13-devil
dan-the-man
SreiesIIGtst
Uneekwahn
Mirkz
Nizmo
Jimih
Wilz
Erik
Steve_SST
Jeff_SST
Todd
Adrian
Sexzilla
R33_Impul
EVL_R33
Magic1
MetBlueGTS-t
Yazid
Judged
Nik
Taynewguy
MrGTST
Nexus6
MLCrisis
oo FARK big lose dude!!!
I completely forgot about this...
i didnt think i was actually able to take part, hence why i ceased paying such close attention to it. I hadnt actually been told that i was or wasnt allowed to enter... DAMNIT!
i wanna go... SHITE!
I will see what i can do... my missus wants me to goto perth with her on sunday... will see if i can change it or not.... :D
Will definately try get in there but... we need more N/A's !!! :)
This has been emailed to me from Rick:
1) if you could please appoint some 'Marshalls' for the day as I don't want
to have to be running around shouting myself hoarse trying to get people
into place etc.
This has happened before, no-one helps out and it all gets a bit
...."what's goin' on here ?"
2) Again, I cannot emphasise enough that this is NOT a free Motorplex
session, so once any Skylines Australia car turns any wheel 1mm off Anketell
road, it's slow down, no chirps, no dragin' down the approach road to the
front gates.
Likewise inside the Plex.
3) I'd like to get everyone down to the start line area .... I might get you
all lined up along the return road to help with the construction of the
pyriamid - the pyriamid will be built over the start line area.
4) Anyone with a UHF radio, please bring them ... when building the actual
pyriamid, I need to be up in the stands composing the photograph and cannot
run up and down to tell people how to park.
A UHF hand held is invaluable for this ... bring a few please.
5) You and your Club Hierarchy need to;
a - Appoint about 4 cars to go on the front row of the group shot.
This must be an executive decision as I don't want members muttering under
their breath that I have favoured someone or such like
B) You and the club hierarchy need to also appoint about 4 to 6 cars for
mini features ... this is very important that the club hierarchy is seen to
make the decision in this area with my 'guidance'
I should have mentioned this one a long time ago .... incidentally, a mini
feature now in this club feature does not mean that the car involved cannot
have a full feature later on if that car is modified even more.
Mini feature cars should have a decent amount of mods to make the following
spec' sheet look 'good' or 'substantial'
