i can see how a straight bar with 2 fixing points can make something stronger..... but... a bent bar?
Can you explain your theory? Do you know where this is placed?
Edited by Jetwreck
I'm kind of with you on this.. but probably because I have been burnt before with strut tower braces, with many people telling me that make a big difference, then I fork out the cash, install it, and find it makes no difference at all to a daily.
This appears to be a similar item, but tries to tie the lower section of the rear suspension together.
I feel that forces required to flex this section of the suspension member would need to be significant, and a bent metal bar isn't likely to do much to reduce it. But since I have never used one, I can't really make any definitive comments. other than to say that I would be surprised if you would notice any change by fitting this to a normal street car..
I have one on mine can tell you in combination with the front bar (see "Daleo") it corners significantly better than my other Stagea.
Perhaps go to thehttp://www.oxmotorsports.co.jp/24_9.html website and check it out as well as their test results.
So don't buy one, your Eopinion is not important to the other people chasing chassis stiffening mods.
These have been engineered by a reputable Japanese company and tested using complex load sensing equipment, with data supplied. Perhaps you should have compared the massive improvement the front underbody brace made to my M35's handling. Read the thread, we were all amazed by the difference in handling and turn in.
More chassis stiffening please Craig.
A strut brace would make very little difference to the handling on any of our cars, as the strut top isn't taking any side load like the earlier Nissans. We have upper wishbones taking the load, and our engine bays are braced/double walled.
The weak points are the main bolts under the chassis, where the large suspension bushes are located, like the main castor arm bush. These are flogging out badly after 10 years which shows the amount of load they deal with.
Sorry, I forgot to mention, the FSTB was on a J30 Maxima, FWD with McPherson strut, so I would have expected any improvement with a FSTB would be noticable on a front heavy car with that suspension setup.
Sway bar upgrades made a big difference, FSTB and front lower tie bar did nothing.
Common misconception.
The force required to flex or bend a straight bar is far less than that req'd to flex or bend a bar that has a premade bend in it.
The bar in question in this instance has two radii in it so trying to flex it in either direction along those radii would have them fighting against themselves - as would be the case once installed onto the car.
For the V35 guys,
Took me 15 minutes to install.
Preliminary results are all good, short drive around the block and the rear of the car seems to stay flatter, also enhances the ride quality.
Now just waiting on the Daleo special front brace.
Also I just have to customize the exhaust on the drivers side of the diff as it is just touching the bar.
Edited by pv35gt8
Have just driven to work, and travelled over some rough patches of road that normally throw me round like a cork in the ocean, now considerably smoother. Will be interesting to see how the front brace goes when I get it.
Cornering feels quite good (raining, turbo & single spinner = not so much joy) holding flatter with more traction.
Could be in me head but it also feels like it brakes alot better, i.e. better braking performance, but as I said this could be placebo effect.
Sorry Craig, I thought that if there was another V owner letting them know that its a good thing that they might jump on your GB and get a really good price.
But alas, if it can't be seen while they drive down the road, then they don't want it.
Feeling is always better than seeing....
So why do you keep coming into the thread?
Well, it seemed to get a bit off topic anyway.
We should bolt one under your car, let you see the result, then deny you the privilege of running one, ever.
Feel free..
Why is it that some seem to get so upset when you question their results? I got the same result when I told people the FSTB on a J30 maxima did nothing.. with plenty of people claiming it 'significantly reduced body roll', despite the fact no bracing can do that.
Edited by sonicii
guy's the updated list is in this thread...if your on it please check the list to see I have not missed you.
http://www.skylinesaustralia.com/forums/topic/404938-rear-chassis-braces/page__st__60
@pv35Gt8....you can lead a horse to water......! Most people don't realise the positives about the M35/V35/Z33 and bracing.....these cars already have a very good chassis thats why simple upgrades are noticeable. The bracing simply makes the car sit flatter on the road therefore producing more grip.
One question for you though sonicii......If bracing was such a bad idea then why have Nissan fitted the S2 V35's with such a big f#$king brace across the front(much jealous).
To put any kind of chassis brace on a J30 Maxima would be like putting a set of Horse shoes on Cow.....not very noticeable and why would you EVER bother! :P....I didn't even know they had there own forum till now!
Jetwreck, thanks for the partially sensible/reasonable reply, I was starting to think all I would get for disagreeing is flames..
Firstly, I never claimed this would make no difference or is a bad idea.. just that I am highly skeptical about simple braces making much difference.
To your question, if the S2 V35s have the extra bracing, and it makes so much difference, why don't we ever hear people claiming how much better a stock S2 V35 handles compared to a stock S1 V35?
In regard to the J30, yes it was a luxury designed vehicle, and will never handle like a 350Z, but there were many, many posts, on Australian forums and US forums, singing the praises of the FSTB and front lower tie bar, lots of 'huge difference', 'best bang for buck mod', 'car handles so much better', 'corners much faster' claims (it's amazing how much the placebo effect works), I already had stiffer springs, and stronger whiteline sway bars, and figured the chassis wouldn't be designed to handle the extra stress, and would flex more than a chassis of a 'performance' car, which would be stiffer in stock form. So it makes sense that bracing would be more noticeable in this situation. I ordered both the FSTB and Lower tie bar, and they had no noticeable difference to vehicle dynamics. After stating this on the forums, i got 1 of 2 types of replies. firstly, flamed for 'not knowing a thing about cars', or 'would know handling if I fell over it'. (similar to what I see here) or secondly, lots of backpedaling like 'you will only notice it if you have other suspension mods (which I did have), and 'you will only notice it on track/circuit events, and not with normal street driving'.
Feel free to correct me here, but I figure the only thing bracing can do for handling is reduce wheel camber and caster changes on rough roads or heavy cornering, there is no way it can reduce body roll, or make the car itself sit flatter in the corners. If the stock chassis is flexing so much to cause noticeable instability under normal street cornering and rough roads, when you already have uneven surfaces, stones, line marking, etc. Then I would expect to find cracks in the chassis after a couple of years.
As I said.. I am not saying these don't do anything, and I am more than happy and willing to be proven wrong. I am just outlining the reasons for my skepticism.. and a link to a page with a few 'stress measurement' graphs with no axis labels and no notes to show how the figures were obtained, doesn't mean much. Given my previous experience, a few people saying 'huge difference', 'corners much flatter' doesn't hold much weight either.
If I had a spare $200 or so that I didn't know what to do with, I may have even just given it a try for the sake of curiosity.
Perhaps if someone was to do a few 'blind' back to back tests and was able to determine 100% of the time if the bar was fitted or not, it would be a credible result.
- ok, bring on the flames!
Edited by sonicii
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
