Already got DayZ Commander and it doesnt update shit.
It has the button there saying "Update to newer version"
and I click it but it does nothing NOTHING I TELL YOU!
I just want to hunt some players fark the zombies off im out to PK
I'm sure you'll be a unique and dangerous noob.
https://www.sau.com.au/forums/topic/405581-day-z/page/2/#findComment-6467147
  • Replies 127
EVERYTHING and I mean EVERYTHING to do with DayZ has to run as Administrator. This Includes:
Steam (assuming you have ARMA II and OA via steam)
When Installing SIX updater or DayZ Commander
When Running SIX updater or DayZ commander
If you can't get it to update to the latest version you can manually try using
My advice is use DayZ Commander and keep an eye on the percentage of servers running specific versions.
To everyone else, FINALLY had a good haul last night. Played for an hour or so at nighttime and managed to get everything needed to survive in the wilderness. Now off to some army barracks to find some night vision goggles and perhaps some mobile transportation :D
https://www.sau.com.au/forums/topic/405581-day-z/page/2/#findComment-6467576
I hit the jackpot last night. Cruising around the far, far north on a motorbike I found half a dozen tents, few other vehicles (which clan claimed) and one of our members found a fully repaired, fully armed and fuelled chopper!
I pretty much have the perfect set, just need ghillie and range finders. Then go lose it in reckless PK.
https://www.sau.com.au/forums/topic/405581-day-z/page/2/#findComment-6467641
I played it for about 3 hours last night.
Getting used to the run keys etc.
Ended up crawling around for a good 2 and a half hours from house to house trying to find one that opens up.
Found a bell tower with 2 dead guys so I looted them and went hunting with my new revolver.
Got up to a barn where a dude in a gilli suit smoked me
https://www.sau.com.au/forums/topic/405581-day-z/page/2/#findComment-6468704
Im going to hunt you haha
No need. Hacker came into the server within less than 5mins of being in, teleported to everyone then killed them within 10secs apart. That being said, Me and 2 mates had to start again and ended up coming into an 8vs3 battle. We won as I survived on 2900blood. Highlights: I had a blood pack, found a gilli suit, protected the corpse's and my mate got his coyote back-pack back. Time to be a grass ninja.
Edited by Reflector
https://www.sau.com.au/forums/topic/405581-day-z/page/2/#findComment-6469223
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
