  • Replies 68
1 inch runners will keep the gas speed high too. Unless they are a restriction why go bigger?
Exactly, when you look at how small the collector to the T3 flange is, it seems bizarre when you read about people increasing the size of the exhaust ports. My mechanic has a drift car with well over 300 rwkw that runs a similar manifold with 1" runners and the small runners don't seem to choking his power output. As you've said, it's all about keeping the gas velocity as high as possible to spool the turbo hard.
If you keep them small then its believable that it might increase response, when you see people with these massive tubular designs designed for peak power though you will often loose response.
Small runners, sweeping radius and internally smooth pipe joins/merge collector will make a sweet manifold. Anything with large pipe or tight bends wouldn't be suited (at this power level anyway.)
It's interesting Kyle (6boob) won't change his piping sizes, even if the customer requires it for a particular power output.
He has made some manifolds with 1" pipes... He was testing them on sr20s a few years ago mainly for street and drift cars where response was favoured. I think he said he found it was only good upto a certain power level before it became too restrictive. Can't recall all the details, it was a while ago now.
This manifold makes my GT-RS so responsive that you can hear the turbo whistle as soon as you blip the throttle from idle.
Mike at MX said he has fitted this manifold to a RB20 with a 3076, and it hits 20psi at 3600 rpm!
4 pages to come to the conclusion that a GTRS running 20psi on an RB25 doing track work is going to exceed the design temps? Pretty obvious, HKS rate them at 0.9bar on an RB25.
I wouldn't put more than 1.1 bar through one on a street/cafe racer RB25. You're not just past the turbine flow, you're off the compressor map too.
20psi is around 2.6:1 pressure ratio.
Rolls, here's a comparison of what the manifold change has done to my power curve (same dyno/same boost/same gear). The increased spooling isn't so evident on this graph, though on the road the change in response in incredible.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
