Hey all, have a HEAP of leftovers from a half-cut
Location in Eight Mile Plains
Will be letting go at 'need it gone' prices
Auto gearbox - $100 (Comes with torque converter and flywheel)
Auto cluster - $50 (No idea how many k's, haven't powered it up)
R34 GT-T Auto ECU - $100
Driver and passenger airbag - $50ea
Stock radio and pocket with climate control module - $50
Dash mounted gauges - $50 (Stock volt, oil temp and boost)
Dash - $50
R34 GT-T front calipers - $150 (Suit 310mm rotors, uses 14mm bolts to knuckle)
R34 GT-T steering rack with rack ends - $100
R34 GT-T stock SMIC with duct - $50
R34 GT-T engine cross-member - $50
R34 GT-T auto radiator - $50
R34 GT-T LCA's - $50pair
Standard airbox with AFM and duct - $100
Starter motor - $50
A/C compressor and bracket with condenser - Free
Steering column with stalks - $50
Coolant overflow bottle - $20
Windscreen washer bottle with both motors - $20
Pictures upon request
I'm bound to forget something so just ask
Most likely keeping engine loom
  • Replies 54
Posted Images
RSFOURDayz, I'll have to check the dash for the coin tray, didn't notice one. Do have the duct though and will separate, $20pp if required.
66yostagea, fan isn't available.
Yup cool, trays not a worry, i have one just one of the retaining pins is knackered. I'll grab that duct, i'll take a pic of my stagea one so ya know which piece i need.
This is the piece I need. Plus, if you have them, the clip things that hold them to the rad support. Can I pay you for it on Monday? Send me through bank details and i'll send you my address.
Edited by RSFOURDayz
Yes, side-mount is still available.
Airbags = Gone
AFM = Gone
Rotors & calipers = Gone
Neo engine cover = Gone
Dash gauges = Gone
A/C compressor and condensor = Gone
so he did buy the bags. (that was a mate of mine)
side mount with brackets -$? (PM me,)
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
