Hey all, have a HEAP of leftovers from a half-cut
Location in Eight Mile Plains
Will be letting go at 'need it gone' prices
Auto gearbox - $100 (Comes with torque converter and flywheel)
Auto cluster - $50 (No idea how many k's, haven't powered it up)
R34 GT-T Auto ECU - $100
Driver and passenger airbag - $50ea
Stock radio and pocket with climate control module - $50
Dash mounted gauges - $50 (Stock volt, oil temp and boost)
Dash - $50
R34 GT-T front calipers - $150 (Suit 310mm rotors, uses 14mm bolts to knuckle)
R34 GT-T steering rack with rack ends - $100
R34 GT-T stock SMIC with duct - $50
R34 GT-T engine cross-member - $50
R34 GT-T auto radiator - $50
R34 GT-T LCA's - $50pair
Standard airbox with AFM and duct - $100
Starter motor - $50
A/C compressor and bracket with condenser - Free
Steering column with stalks - $50
Coolant overflow bottle - $20
Windscreen washer bottle with both motors - $20
Pictures upon request
I'm bound to forget something so just ask
Most likely keeping engine loom
  • Replies 54
Posted Images
RSFOURDayz, I'll have to check the dash for the coin tray, didn't notice one. Do have the duct though and will separate, $20pp if required.
66yostagea, fan isn't available.
Yup cool, trays not a worry, i have one just one of the retaining pins is knackered. I'll grab that duct, i'll take a pic of my stagea one so ya know which piece i need.
This is the piece I need. Plus, if you have them, the clip things that hold them to the rad support. Can I pay you for it on Monday? Send me through bank details and i'll send you my address.
Edited by RSFOURDayz
Yes, side-mount is still available.
Airbags = Gone
AFM = Gone
Rotors & calipers = Gone
Neo engine cover = Gone
Dash gauges = Gone
A/C compressor and condensor = Gone
so he did buy the bags. (that was a mate of mine)
side mount with brackets -$? (PM me,)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
