Ok, cylinders 1-2-6 have gone in my car (RB25DET)
Long story why, but now it needs a rebuild :D
I've thought about 3ltr, but for the time being, lets just look at the RB25 as the motor i am rebuilding.
I have a max budget of $7000 to spend on the motor end of things.
So guys, what can i get for my money?
And how can my money be spent best to get the best results on a limited budget.
I know i need forged pistons of some description. But other than that i am not sure.
The power figure i'm aiming for is around 300-330rwkw after the build, so it has to be a strong motor.
Which then brings me to rods... do i need them too? I imagine that i will have too.
My Redline will be set at a conservative 7500rpm, but if i can increase to 8500 within my budget it i wont complain.
At this stage i want someone to do it for me.
But in saying that, if it's going to cost me too much money to pay a workshop...
I do have a few mates who can help me out in thier spare time.
That though, means more down-time for the car as it'll be in their spare time which they dont have a lot of.
Any advice/tips and approximate prices would be appreciated guys.
Am i being un-realitic wanting it rebuild for $7000?
- ash
https://www.sau.com.au/forums/topic/40595-7000-how-to-spend-it/
or me..
your mates huh? and how long did it take for that turbo to go in...
then again certain workshops won't be much better. Least if you do as much as possible yourself, you only have yourself to chase up to get stuff done. Then again, if you stuff something up, you only have yourself to blame as well :D
Ok i've got my 31 in bits at the moment and just getting all the parts together to get the rb25det back together.
I'm going to spend about $4k all up on the engine on:
-forged pistons (arias, wiseco or je gear)
-cams (around the 265 8.7-9mm lift mark)
-crank & GTR rods balanced (maybe cryo treated)
-new arp rodbolts, gaskets, seals, clevite bearings
Although I’m getting all my machining done for next to nothing I’m sure you could do a nice rebuild for 7k if you are willing to do most of the work yourself.
But dont take this as 100% correct advice till i get the bloody thing back together and running :headspin:
John
in HPI theres an add for
Venolia forged pistons
Grant chrome rings R.E.V I-Beam forged conrods
Tomei metal head gasket
genuine nissan full engine gasket kit
they say its good for 600ps+ sounds ok to me
$3999
Righto my RB20DET blew in my r32 - Now for my rebuild it costed - hang on see this link :
http://www.skylinesaustralia.com/forums/sh...&highlight=joel
I have done all work so far myself (Ripping out rb20 and installing new rb31det)
Parts list :
rb30e block
rb25de head
r33 gearbox
OS GIKEN twin plate
sinle piece tailshaft
AP Power fc + HC
550cc injectors
STP cam gear
600x300x70 IC
HKS 3037s with manifold (im organizing atm)
Motor was built with head and timing setup using wiesco forgies, balanced, bored 40 thou over, ported head etc cost all up (as a long motor) roughly $5500 without using forged rods. Add another $1600 -1800 for them on top of final price.
Other parts all together costin goughly $6000.
Then add cost of tuning car, then retune once run in, + install camgear turbo + manifold + cost of new pipework.
Still havent bought cams (after run in) or the fuel pump or z32 - which i need asap.
Should be RELIABLE up to about 330rwkw is as far as i want to go everyday, and pull close to 700Nm of tourque
Give u an idea when to stop spending??
rather than reinvent the wheel a standard rb26 with low mount turbo upgrade should come in around budget and produce 300rwkw.
I'm not reinventing any wheels!
I've got all the other stuff to get me too 300rwkw, just not the motor to hold.
I took around a month and a half, but it was a lot of work i must admit.
And like i said, it was all done in spare time which there isnt much of these days. :D
mesmer has the right idea rb 26 crank and rods and good forgies metal head gasket cams if you want and clean up the head a bit. n1 water and oil pumps.
Does putting in a 26 crank/rods still have it as a 2.5ltr?
and while its out a good clutch
also go the injectors etc if you arent already.
I've got all the 'extras' that you need all covered already :(
I might have to grab me a copy of HPI !
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
