Hey guys.
Wanting to put a TPS on my aftermarket throttle body.
Just wondering if anyone know what fits?
Can I just run the standard rb25 tps into it?
The motor is a rb25/30 in a r32 and the tps was originally 3 wire.
I have the run new wires to the ecu as they're not there anymore and the ecu itself is Microtech lt10s.
https://www.sau.com.au/forums/topic/405979-tps-on-90mm-throttle-body-help/
Might be useful info for you but I just brought a new R33 GTR TPS to replace mine which has a big single throttle body only to discover when i went to swap them that the one on it is from a S13 or 240SX or Infiniti something.? Number on the back of the TPS is
A22-641 921. Whereas the R33 GTR one is A22-648 J11, they rotate different directions. When they are mounted the GTR one rotates clockwise and the other is anti clockwise, according the arrow on the back".........
No sure if this is of any assistance, but there it is.
Ps Just had a good look at those pics and neither will go on that throttle body /-;
Edited by tricstar
ok after a very frustrating 30 minutes down at Nissan, cancel the info above.. the one I have A22-641 921 is not off either of those cars and may be off a nissan V8 G50 or something ?? :wacko:
Starting my own thread now... hope I get more help than I have been to you !
Edited by tricstar
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
