I have been looking around at wheels as I am going to be replacing my stockies.
I was looking at these: http://my350z.com/forum/wheels-and-tires/512477-varrstoen-es-1-1-2-deep-polished-lip-19-a.html
But the 1.1.1 in 18 x 9.5.
They have a couple of offsets available, and I don't really understand tyre offsets. I want to fill the guards nicely on my R33 GTR.
The fitments listed are:
18x9.5 +12 5x114.3
18x9.5 +22 5x114.3
18x9.5 +30 5x114.3
Thoughts?
https://www.sau.com.au/forums/topic/406051-think-i-have-chosen-my-wheels/
  • Replies 54
Posted Images
Sorry I was meaning 10.5's lol. 10.5 +12 is perfect on 33 imo
you reckon?! Theres a silver 33 gtr here that has 10.5 +12 and he has to run camber front and back to get them nice inline with guard. Whereas 10.5 +15 are dead in line with the guard
Just wondering if these would fit and if so thoughts on what they would look like given they are only 18 x 8's?
Specifications: -
  • Design: BBS LM Styling
  • Color: Hyper Silver
  • Wheel Size: 18-inches
  • Wheel Width: 8-inches
  • Stud Pattern: 5x112 PCD
  • Offset / ET: 35
  • Center Bore: 73.1
Nope won't fit, wrong stud pattern. Skylines (well, likely most Nissan 5-studs) are 5x114.3mm (someone confirm that)
Also that offset+width combination would look terrible in my opinion. The stock standard R33 GT-R rims are 9" wide and +30 offset, which means they're both 1 inch wider and the edge will sit ~17mm further out than the above rims.
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
