have installed some 1000cc Xspurts and im confused about the settings,
ive put in 37% correction, and the latency of the injectors is 0.990 at 14Volts and 43.5psi
so does this mean its 0.7-0.990= -.299???
when i put that in the car wouldnt even fire, when i put in 0.18 or 0.30ms it fires and wont idle but very rough, when i tried 1.0ms it was quick to fire and did idle with some throttle but still jumpy and rough...
need some help here. wondering wether theres a massive vacumn leak or if the settings are totally wrong..
https://www.sau.com.au/forums/topic/406328-injector-settings/
The 37% correction is for the size of the injectors relative to standard. You do not use that correction when talking about the latency, and you do not refer to the original latency either. You just put in the latency number that they gave you, which is 990 micro seconds, or 0.99 milliseconds. Job done.
the tuner has emailed me that its the new latency - 0.7,
originally with the nismo 555's it was 0.18
so your certain its just put the 0.99 in then? cause its either not right or theres a massive vacumn leak..
So where the hell did the 0.99 number you've been going on about come from?
No. If the latency you have been told is 0.7, then put in 0.7. Do not pay ANY attention to what the old latency was, as it simply doesn't matter. There's no ratio, there's no correction factor. There is just numerical value.
the 0.990 comes from the deadtime chart from Injectors Online where i bought them ....thats for 43.5psi and 14volts
As far as i know from reading the forums, the standard latency is 0.7?? and your supposed to use this to calculate the adjusted latency based on the calculation new latency (0.990) minus 0.7 witch would be 0.2990...
I tried this value and it was rough as guts, and i tried 0.990 and it was even worse,
using the 0.990 from the injector chart as you have suggested drenched the plugs... im still thinking wether a vacumn leak is the course or this latency value...
Edited by SliverS2
This is PoweFC yeah?
In which case, I reverse my position on having to do maths. The standard RB25DET injectors have latency of about 0.52 ms. Your new ones are 0.99, yes? So your correction is 0.99 - 0.52 = 0.47 ms. Try that.
I didn't realise you were playing with a PowerFC until I read your sig. Bloody stupid way to set latency if you ask me.
cheers
  • 2 years later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
