hey people, just wondering because its pretty fustrating. doesnt matter how much soap i put it suds up nice for first few seconds then after you start using it, it goes to water,
ive tryed maguires wash and wax, and mothers carwash (both not cheap products)
i first put hot water then use gerni to get it mixed nicely
anything im doing wrong?
https://www.sau.com.au/forums/topic/406490-carwash-soap-doesnt-sub-up-well/
ideally the best way is to first fill up your bucket with water then add the soap whist mixing it in by hand - the reason for this is that you want the soaps and suds to be kept inside the water, keeping it slippery and lubricated
so when you use your mitt/sponge to absorb it and go over your car, there is the maximum amount of slip and lube between the mitt and your paint
IMO bubbles are wasted lubricant that should be in your wash solution not on top
also pretty basic but make sure you are applying the correct amount of wash as per the size of your bucket - ie wash and wax recommends 30mL/4L so if your bucket is 8L, use 60mL if it is 12L use 90mL and so forth - i bought a plastic measuring cup from the $2 shop which allows you to use the correct amount without wasting any
One of the better car wash vids - if you wna skip straight to where he pours the soap into the bucket its @ about 5:00
<iframe width="420" height="315" src="https://www.youtube.com/embed/rqdEVtOPKAM" frameborder="0" allowfullscreen></iframe>
Edited by squareznboxez
Suds really aren't too important mate, Final inspections PPBS (high end soap) doesn't sud very much at all. neither does auto glyms.
All you need are lubricity and a PH balanced solution as was previously mentioned.
Suds = useless and mean nothing. People have been made to "think" that unless it 'suds up', you don't have enough or it's not a good solution.
As Jonno34 pointed out, what you want is a pH neutral solution with high lubricity. Water down some of FI's PPBS (Paint Pampering Body Shampoo) and run it through your finger tips, even diluted you can still tell the lubricity is very high.
I also wouldn't be putting my shampoo solution in a bucket either. The best way IMO is to have your buckets full of clean, hot water. Do a pre-rinse with PPBS solution and hot water and then i wash the car with a spray pack of washing solution. So as i go around i put a few sprays on the panel, a few sprays on the washing mitt. This way you have even coverage of washing solution a;ready on the panel you're about to clean.
I use an old brake-cleaner pump-pack as the pre-rinse dispenser and then an old 500ml FI trigger bottle for when i'm doing the main wash. Use less product, nice big even spray from the pack gives you good coverage of the panel and you keep the rinse water the way it should be, clean rinse water (well for as long as you can)
  • 4 weeks later...
Not necessarily true about the suds thing. I have recently bought a foam lance which hooks up to my Karcher pressure washer.
This creates a really nice thick foam that sits on the cars surface. The reason for this is to let the suds suck up any dust and dirt that isn't stuck to your paint.
You then rinse it off and begin your normal washing process whatever that may be.
I have found that this actually does work quite well, in reducing the small scratches you create when you are applying your normal wash with a microfibre mitt or sponge.
I wasn't really sold on it but i am def sold on it now.
lol science of washing a car...
Wanna know how I do it? $5 Armorall heavy duty wash and a $2 jumbo sponge. 4 caps in a regular bucket as you're filling it with water. Clears the sinuses and as a bonus it also cleans your car. Squirt panel with water, soap it up, squirt again.
Put some effort into waxing and the washing part won't need to be rocket science. On that note, I use a $7 paste wax that continues to bead after 6 months. Come at me premium products:
Pour the product/solution all over the car when wet " not mixed " Perfect system with no scratch
This is the best way by far , dont f...k around using a capful here and there = use at least a handful straight on the paint all over the car
  • 1 month later...
you quoted your own comment
-_-
Edited by w34ponGT
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
