If John is too busy - and Vision can't - you can go to Australia Best Tyres at Lakemba - Htey did mine no problems.
So what .... John is too busy for you Carlo ?? It only takes 5 mins per side - that's soft.... I'm booked in on Saturday at UAS for potential guard rolling... bring on the 265 semi slicks for wakefield :P
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-835977
i had mine done at tempe tyres,
$40
my paint didnt crack, as long as they heat it up properly it should b all good.
odds are tempe has done alot more guard rollin than any other place.
p.s i dont know them personaly either, (just in case u thinkin)
yeah I got mine done there too, and believe it or not they did a great job :cheers:
just look over their shoulder when they do it :P
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-836228
just look over their shoulder when they do it :cheers:
Rolling guards is like making sausages, passing federal legislation or childbirth - you don't wanna be there when it happens.
My car will be rolled and painted by the weekend so you guys should have an idea of a what a crap job looks like!
T.
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-836235
So what .... John is too busy for you Carlo ?? It only takes 5 mins per side - that's soft.... I'm booked in on Saturday at UAS for potential guard rolling... bring on the 265 semi slicks for wakefield :D
Problem is that the car is not available for him to do it until later this week. He offered to lend me the machine but I am way to busy and also not wanting to **** the car up.
I have 255s on the front, so I am hoping they can roll the guards enough to not cause any issue.
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-837160
They fit.. Just
I am thinking of changing the rubber on the fronts to 235 or something on the same rim..
good idea
strectch the rubber, i got 235 rubber on a 9.5 wide wheel,
reason 1 it looks good ( i think so anyway)
reason 2 i cant afford 265 rubber.
any1 know if stretch the tyre is bad 4 it?
i know its not recommended but is there real chance of damage?
any1?
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-837987
I went to a tyre place. They can even put 225 wide rubber on a 9inch rim. Sheesh
I went to vision, they are really nice guys who got my front bar sorted for me. However I am not that happy with how they rolled the guards, they just seemed to lip them. I am going to go out to tempe tomorrow and get them to do it some more.
It seems that vision dont have the machine required, but I know for sure that tempe can do it... how else do you fit 20inch chromies on a swift. :(
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-838883
Hi Carlo, couple of Q's please...
What vehicle are you doing this work to ?
What width & diameter of wheel do you wish to fit ?
Reason I ask is I would love to fit 17"x 9" wheels f&r to an ECR33. But they well & truly protrude beyond the front guards. is rolling/reshaping an option, or do I need GTR/aftermarket guards ???
good thread, very interesting.
Thanks for your help
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-838981
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
