If John is too busy - and Vision can't - you can go to Australia Best Tyres at Lakemba - Htey did mine no problems.
So what .... John is too busy for you Carlo ?? It only takes 5 mins per side - that's soft.... I'm booked in on Saturday at UAS for potential guard rolling... bring on the 265 semi slicks for wakefield :P
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-835977
i had mine done at tempe tyres,
$40
my paint didnt crack, as long as they heat it up properly it should b all good.
odds are tempe has done alot more guard rollin than any other place.
p.s i dont know them personaly either, (just in case u thinkin)
yeah I got mine done there too, and believe it or not they did a great job :cheers:
just look over their shoulder when they do it :P
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-836228
just look over their shoulder when they do it :cheers:
Rolling guards is like making sausages, passing federal legislation or childbirth - you don't wanna be there when it happens.
My car will be rolled and painted by the weekend so you guys should have an idea of a what a crap job looks like!
T.
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-836235
So what .... John is too busy for you Carlo ?? It only takes 5 mins per side - that's soft.... I'm booked in on Saturday at UAS for potential guard rolling... bring on the 265 semi slicks for wakefield :D
Problem is that the car is not available for him to do it until later this week. He offered to lend me the machine but I am way to busy and also not wanting to **** the car up.
I have 255s on the front, so I am hoping they can roll the guards enough to not cause any issue.
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-837160
They fit.. Just
I am thinking of changing the rubber on the fronts to 235 or something on the same rim..
good idea
strectch the rubber, i got 235 rubber on a 9.5 wide wheel,
reason 1 it looks good ( i think so anyway)
reason 2 i cant afford 265 rubber.
any1 know if stretch the tyre is bad 4 it?
i know its not recommended but is there real chance of damage?
any1?
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-837987
I went to a tyre place. They can even put 225 wide rubber on a 9inch rim. Sheesh
I went to vision, they are really nice guys who got my front bar sorted for me. However I am not that happy with how they rolled the guards, they just seemed to lip them. I am going to go out to tempe tomorrow and get them to do it some more.
It seems that vision dont have the machine required, but I know for sure that tempe can do it... how else do you fit 20inch chromies on a swift. :(
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-838883
Hi Carlo, couple of Q's please...
What vehicle are you doing this work to ?
What width & diameter of wheel do you wish to fit ?
Reason I ask is I would love to fit 17"x 9" wheels f&r to an ECR33. But they well & truly protrude beyond the front guards. is rolling/reshaping an option, or do I need GTR/aftermarket guards ???
good thread, very interesting.
Thanks for your help
https://www.sau.com.au/forums/topic/40694-guard-rolling/#findComment-838981
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
