Hey guys
Going to be getting my new rims in the next few weeks and I need to get my guards rolled and a wheel balance and alignment done.
Anyone know of a cheap place that you have experienced.
Or if anyone knows how to roll the guards I am more then happy to pay you for helping do it.
Cheers
Kasko
https://www.sau.com.au/forums/topic/407293-guard-rolling-wheel-alignment/
I work at jax fyshwick, we used to roll guards til our guard roller broke from over use. Then us like most shops stopped doing it because no matter how many times you tell people that most the time your paint will crack and or flake even when heated with a heat gun, they still want you to pay for a respray. You can buy a roller off eBay for about $100-$130 and do it yourself?
I am a full time wheel aligner and it'll cost ya $66 for a 4 wheel alignment at our shop.
Edited by RS4-S
We do guard rolling, and there is always a risk of cracking the paint or flaking at the seam of the guard where it tucks under when lipping the guard.
When rolling the guards out it becomes a bigger risk as you are stretching a wide area of the paint just above the lip and thats why most shops including us mention before work comences that there is a risk that it can crack/flake the paint when rolling/lipping even with a heat gun..
The reason shops mention the risk is to cover the shop if there are any cracks in the paint due to rolling the guards and the paint not being flexable.
We charge $50/guard to roll/lip we arent able to do wheel aligning yet.
does that include cars with adjustable upper arms?
I'm with TiTAN here, are you able to do a full setup adjustment for me - ride height (lower), then fix camber and alignment? Theoretically all I need to do is lower it again to wherever it was before, then all the rest should be near on correct lol
Titan and Troy. The more adjustments you have, the better I can do my job. $66 would cover front and rear camber and toe etc and front caster if you have adjustable tension rods. Lowering a by means of winding down Coilovers would attract an additional fee. Il enquire pricing for this tomorrow of youre interested. If you have fully adjustable everything you can give me preferred specs otherwise I set it to factory/my specs. IF you give me some wack specs you found online with stupidly large cross camber and caster differences and your car pulls like a 12yr old boy, il just say I told you so.
I dont need any pumping of the guards etc.
Just a standard roll of the inside is what I think the guys in the wheel section were telling me.
Going to be lowering the car and fitting some 18x9.5 +22's with 235/40/18
The coilovers should give me the camber I need
LOL gold.
Fair enough, I might just pull my finger out and lower it myself then bring it past if it still handles like a heap of shit :)
Lowering/raising vehicle with coilovers fitted will cost about an hours labour ($99). Make sure you adjust your Coilovers at the bottom and not the spring perch as you are just changing spring preload and reducing shock travel.
Hehe yeah I know :P I raised them myself for the engineer's cert. I can do them myself, I just really couldn't be f**ked hahaha
That standard roll can still crack and cause reasonable paint damage.
Trust me :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
