So my wife's R33 A/C has been acting kinda funny lately. Even with the climate control turned completely off, the A/C still stays on. It blows very cold and all of the mode/blend doors are working properly, but it just won't stay off. Any ideas?
https://www.sau.com.au/forums/topic/407372-r33-gtst-ac-acting-wierd/
Very good question! She says that she notices that the compressor cycles on and off even when the climate control is turned off completely. She does notice that when she has recirc on and the Climate control off she doesnt feel cold air blowing through the floor vents. But if she has everything off and its on fresh air even on a hot day she still feels cold air on her feet. I have rode with her and experienced this as well. I just cant figure out why the compressor is getting power with the climate control turned off completely. Possibly a stuck/shorted relay?
Edited by Gojira5767
Hi Gojira,The ac system has a self diagnose system,do a google search you might only find it for the R32,but it's similiar in function. hope this help's.Here u go found it for u http://www.gtr-owner...ic-ac-test.html.
Edited by I gotta R34gtr v-spec
Maybe you're hearing the AC fan kick in, not the compressor? the AC fan will kick in automatically when the coolant temp goes over 95C. Naturally you won't even realise coolant temp is 100C as the coolant temp gauge doesn't really go near the red till about 120C
Ok, so I ran the diagnostic and came back with code 25(Sunload sensor). Does this cause the A/C to come on automatically when its faulty even when HVAC is turned completely off? Mode doors are all operational, and Diag Mode 4 shows "41"? Im assuming thats a blower motor check, as it turns it on during this mode. And on mode 5, the temp sensors are reading 31 & 32. Which I calibrated both to 31 degrees. I guess I need to replace the sunload sensor regardless huh?
Also, I haven't noticed the A/C fan kicking on, but then again the temp hasn't gotten that high. I have Power FC's on both cars, so I am constantly monitoring it. But your right, the gauge doesn't accurately reflect how hot its actually getting.
If u did the test in the garage or at night u will get that result,u need to do it in the sun light.If u want to try the r34 service manual,here's the link http://www.importworkshop.com/files/manuals/nissan/R34_service_man.pdf and go to the a/c section.
That makes sense. I will try it again tomorrow then. And I think I have the R34 FSM printed off somewhere. If I cant find it I will definitely use the link. Thanks! This is just such an odd problem, something has to be sending power to the compressor at all times. I may just replace the relay for kicks.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
