28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 138
Route will be disclosed at start meeting point on sunday.
As per normal stagea and sau cruises all road rules will be adhered to and no hoon behaviour will be tolerated.
Cheers
jason
I'm keen for a drive Sunday morning, please pm me the details.
Could I please have some details? Thanks.
PM's sent.
Anyone else I missed and/or late additions?
Hey Ryan
Looks like im in.. picking my car up today at 2pm then straight to regency for vin check and rego. If i dont get rego sorted today ill let ya know
Good news mate! Fingers crossed.
If it doesn't work out there's plenty of room in my car, so no stress.
I will be heading to Goolwa after cruise to visit family so no lunch for us. Its my wife's first cruise. I have also invited a few M35 drivers I know. I think we have a chance on beating the record for biggest Stagea cruise in SA.
Still working out which one of mine I'll be bring. But think its heading towards the cruiser of the two instead of the new one. May even have them both out if the Fiancé wants to drive the cruiser. But doubt it.
Oh and I'll have my diagnostic tool out if people need me to check codes. One person has already asked. So u can ask on the day if needed
Just putting it out there, not sure if it has been taken into account when organising the meet point/route but the 'Bay to Birdwood' is also on this sunday!
Just saying. :closedeyes:
BTW I prob wont be able to make it; might have to help a friend pick up whitegoods so I might only make the meet point.
Maybe next time.
Edited by YEE-HAA
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
