Shaved head, piercings, covered in tatts, both arms, back, chest lol
I've shaved the head right back a couple of times, got 4 piercings on my ear/face, one tatt on shoulderblade..but you win :P
Lifts kettlebells in Ugg boots. lol
Kicker right there ladies and gentlemen.
6'6" and 160kg. He's 21yo and had his first ever session on June 8 2010
He failed a 40kg x 5 bench press that day, only got 4. He weighed 105kg
He now squats 300kg, bench presses 180kg and deadlifts 300kg
Those figures are just obscene.
The best motivator for improvement is competition
The highest level of competition is Worlds
If you cant make big improvements going to Worlds, may as well hang it up now
Tolga, Max is now 89kg in the morning, he wants to lift in the 100kg class next year
Jacks improvement has come about because of his 55kg weight gain, plus not missing workouts
Yeah Jack is obviously a bit of a unique case, his genetics are obviously near on PERFECT for powerlifting. Normal people don't get that huge and that strong. He's gifted, that's for sure.
I'd love to get into competition, but since I ultimately lift weights for appearance reasons, I can't make the time for competition regimes :(
Spiros, Emad and Max all hit PB's today, 17 days till they lift at Worlds
Spiros squatted 230kg, Emad squatted 232.5kg and Max squatted 250kg
Nina and Amanda both hit bench PB's, theyre off to worlds as well
Amanda benched 67.5kg and Nina benched 77.5kg, thats 2.5kg above her own WR
Had 5 new people join the gym this week, strength is on the rise
Waiting for Nick to do a Saturday morning session, best session of the week
Me? not sure I can hang with those boys! what's the go on Saturdays? I could really do with some coaching...
That squat from Max was soooo smooth, serious power
How much does Emad weigh? bloody strong for a lean bloke!
So in an attempt to get stronger out of the hole I setup the pins at the very bottom squat position and did dead start squats... I attempted the PPP program in this fashion but it was not happening... had to drop 10-20kg off each lift! ... bloody hell its hard with no bounce
Then bench, going well, trying to practice the pause
Then straight leg deadlifts standing on blocks... stretch those hammies! I can barely touch my toes:/
Dips / face pulls
good session
already feeling better/stronger... even pinched some protein powder off my old man
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
