all i do is bench, deadlift, and pullups....sometimes squat when i'm not being lazy. Seriously i struggle to spend more than 40 minutes in the gym these days.
But i have abs....how does that work???
Cmon guys, by now you should all know abs/being lean/ripped whatever you want to call it, is all diet. You can squat 300kg's and be fat, and you can squat 300kg's and be ripped.
The weights don't give a shit about your physique, they just want to be lifted. You alone are in control of your physique.
On a side note though, the more muscle you have, the more you can afford to eat junk food and shit....like me eating ice-cream every night ;)
Results from todays Novice comp
Powerlifting
Vu - 78kg - 115/82.5/130 - 327.5kg - 219.21 points
Matt - 114.6kg - 125/95/200 - 420kg - 233.79 points
Brent - 99.7kg - 140/105/250 - 495kg - 288.11 points
Chris - 82.4kg - 160/120/180 - 460kg - 296.74 points
Nick - 86.4kg - 170/115/215 - 500kg - 313.17 points
Jesse - 71.3kg - 165/100/190 - 455kg - 325.62 points
Zoran - 112.8kg - 190/135/260 - 585kg - 326.86 points
Bench only
Dylan - 89.9kg - 92.5kg - 56.63 points
Spiros - 112.5kg - 145kg - 81.07 points
Martin - 86.3kg - 145kg - 90.89 points
Zoran beat Jesse by a point in the meet, awesome lifting by Zoran, this was his first ever meet. Zoran is the guy who contacted Bobby about PL in Frankston, and Bobby told him Frankston was cultural desert.
Zoran will be doing ProRawFour next month. Thanks Booby
Nick totalled 500kg, which was his goal, this is his 2nd novice comp
Brent pulled 250kg
Thanks to Emad, Graham, Wayne and Max for judging
Thanks to Jack, Ross, Pete, Daniel and Graham for spotting and loading
Thanks to Sussy for scoring
Thanks to all the lifters and large crowd spectating
Edited by markos
Thanks to all the judges and spotters/loaders... was great because everything moved so smoothly and quickly
cheers for the free Tshirt!... 'This object is the part of this territory' clearly someone in Slovakia was using google translate lol
looking at the video I think there was more in my bench and deadlift... pretty sure I maxed the squat though (it was pretty ugly)... Markos did say to take 165kg... so I took 170kg... maybe next time I should listen!
anyone who is thinking of having a go definitely should... pretty nice having people you don't know cheer you on... a very different atmosphere than your average gym
Good day out, atmosphere down there indeed really motivating (half the reason for my trip down), some very strong guys for a novice comp.
Solid effort Nick, 500kg total, huge!
Only took me 35mins to get home Nick, so realistically it's not that far provided traffic isn't farked. :D
wow that's great time... easy in that rolling couch your driving now;) good choice of car for after a squat session, a GTR isn't ideal haha
thanks for coming
TTT: cheers mate, hope you get that back sorted
Was good to finally meet Ash, I've know of him and known his mates for 6 years yet we've never met
Might repay the favour and support his new venture shotly
Lot longer than 6 years, I'd be pegging it at around 8-9!
Good to meet you in person finally as well, once I'm off shift work, I'll be down for a chat :)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
