so how to a practice sitting back more? my knees are well forward of my toes at the bottom, shins should be more vertical yeah?
legal depth? might have gotten away with it there... was my worst lift for the day and I went 9 for 9 so happy enough... I seemed to have pulled up without any injuries other than general soreness so might get straight back into it tomorrow night... see if I can't improve ye old squat technique
I'm not the best person to ask but here is my understanding of it
Its pretty simple... start off very light, some just use the bar... lots of reps making sure to concentrate on technique... then just slowly start adding plates but just doing a couple of reps every time, making sure to be nice and explosive... you want to be nice and warm but not fatigued... there are percentage based programs out there that give you exact specifics on how to approach it but everybody's different... experiment and see what works for you
I used to train by doing the standard 15, 12, 10, 8, 6 as I went up in weight and with fairly short rest times... then if I had some gas left I'd maybe attempt a 1rm but it never worked very well
much better to go something like 20, 15, 5, 3, 2, 1, 1, 1, 1 ... so the 20 and 15 (just rough numbers) done with a very light weight or just the bar... then the rest of the sets your nowhere near fatigue... in fact these should be done with the strictest form and really concentrate on speed (on the concentric portion)
then load up the bar, get a spotter and go for it
Nick - re: sitting back more.
You will need a wider stance.
if your feet are wider, and knees out, it puts the hips in a position to drop down and back.
You also need to have the bar lower on your back.
Only problem with this is that you will also be leaning forward more at the hips (ie your chest close to your knees.)
Rippetoe teaches this method of sitting back and hip drive etc etc.
Up to you which way you go, but as I'm sure Markos will tell you, changing your technique to chase a few KG usually ends up with injuries or losing kgs on another lift.
Give it a try with no or low weights if you want.
first few weeks of wider stance, knees out, arse back, hip drive gives mega pains in the hips, lower back, inner thighs and depending on your bar and hand position, you might get elbow and shoulder pain.
Edited by TTT
yeah cheers, that makes sense... I have watched Rippetoe's squat videos
my wife did say 'why do you have your feet so much closer together than everyone else'... my answer was I did it that way so I wouldn't need a wheelchair to get home lol
I'm not really looking at it from a perspective that I can handle more weight... I just think if mobility and glute strength is an issue I shouldn't train around them, rather work on it and improve... that said I don't think I'll ever squat wide! I'm one of the least flexible people on the entire planet, its pretty bad
even though I'm narrow I do keep the knees out fairly well... I have knees like a rugby front rower, they ain't pretty but seem to be fairly strong lol
funny I taught my wife how to squat and had her narrow like me but she wasn't strong enough to go deep... experimented with her stance and she is much better with a quite wide stance
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
